Hi cats,
usually I encode my .mxf files into mjpeg .avi's using virtualdub and the Morgan Mjpeg codec.
For example I have my source .mxf file [C0716.MXF] that result in a .avi (Morgan Mjpeg codec) of 238 MB and the quality is good.
But now I would try to encode the same source [C0716.MXF] using ffmpeg and his internal mjpeg codec.
So I have try this commandline:
but result is a file of 118 MB.Code:ffmpeg -i c0716.mxf -vcodec mjpeg -pix_fmt yuvj422p -q:v 0 -vtag MJPG -an c0716_q0.avi
I wonder: is there a way, in ffmpeg, for improove the bitrate or the quality so I can have a resultant output of 230/250 MB file ?
thanks
Your -q: switch should not be 0. Evidently, valid range is 1-31 (lower being better quality).
Scott -
I tested it and: Values below 2 give the same result as 2. Values above 31 give the same result as 31.
mjpg, mpeg1video and mpeg2video in ffmpeg share same codec implementation - perhaps it is feasible to use some features to improve encoding - in past ffmpeg was capable to produce 10 bit dc mjpeg...
Side to general option there is large list unique mjpeg options in ffmpeg (some of them have no sense (to me) at all):
Code:Encoder mjpeg [MJPEG (Motion JPEG)]: General capabilities: threads Threading capabilities: frame and slice Supported pixel formats: yuvj420p yuvj422p yuvj444p mjpeg encoder AVOptions: -mpv_flags <flags> E..V.... Flags common for all mpegvideo-based encoders. (default 0) skip_rd E..V.... RD optimal MB level residual skipping strict_gop E..V.... Strictly enforce gop size qp_rd E..V.... Use rate distortion optimization for qp selection cbp_rd E..V.... use rate distortion optimization for CBP naq E..V.... normalize adaptive quantization mv0 E..V.... always try a mb with mv=<0,0> -luma_elim_threshold <int> E..V.... single coefficient elimination threshold for luminance (negative values also consider dc coefficient) (from INT_MIN to INT_MAX) (default 0) -chroma_elim_threshold <int> E..V.... single coefficient elimination threshold for chrominance (negative values also consider dc coefficient) (from INT_MIN to INT_MAX) (default 0) -quantizer_noise_shaping <int> E..V.... (from 0 to INT_MAX) (default 0) -error_rate <int> E..V.... Simulate errors in the bitstream to test error concealment. (from 0 to INT_MAX) (default 0) -qsquish <float> E..V.... how to keep quantizer between qmin and qmax (0 = clip, 1 = use differentiable function) (from 0 to 99) (default 0) -rc_qmod_amp <float> E..V.... experimental quantizer modulation (from -FLT_MAX to FLT_MAX) (default 0) -rc_qmod_freq <int> E..V.... experimental quantizer modulation (from INT_MIN to INT_MAX) (default 0) -rc_eq <string> E..V.... Set rate control equation. When computing the expression, besides the standard functions defined in the section 'Expression Evaluation', the following functions are available: bits2qp(bits), qp2bits(qp). Also the following constants are available: iTex pTex tex mv fCode iCount mcVar var isI isP isB avgQP qComp avgIITex avgPITex avgPPTex avgBPTex avgTex. -rc_init_cplx <float> E..V.... initial complexity for 1-pass encoding (from -FLT_MAX to FLT_MAX) (default 0) -rc_buf_aggressivity <float> E..V.... currently useless (from -FLT_MAX to FLT_MAX) (default 1) -border_mask <float> E..V.... increase the quantizer for macroblocks close to borders (from -FLT_MAX to FLT_MAX) (default 0) -lmin <int> E..V.... minimum Lagrange factor (VBR) (from 0 to INT_MAX) (default 236) -lmax <int> E..V.... maximum Lagrange factor (VBR) (from 0 to INT_MAX) (default 3658) -ibias <int> E..V.... intra quant bias (from INT_MIN to INT_MAX) (default 999999) -pbias <int> E..V.... inter quant bias (from INT_MIN to INT_MAX) (default 999999) -rc_strategy <int> E..V.... ratecontrol method (from 0 to 1) (default ffmpeg) ffmpeg E..V.... default native rate control xvid E..V.... libxvid (2 pass only) -motion_est <int> E..V.... motion estimation algorithm (from 0 to 2) (default epzs) zero E..V.... epzs E..V.... xone E..V.... -force_duplicated_matrix <boolean> E..V.... Always write luma and chroma matrix for mjpeg, useful for rtp streaming. (default false) -b_strategy <int> E..V.... Strategy to choose between I/P/B-frames (from 0 to 2) (default 0) -b_sensitivity <int> E..V.... Adjust sensitivity of b_frame_strategy 1 (from 1 to INT_MAX) (default 40) -brd_scale <int> E..V.... Downscale frames for dynamic B-frame decision (from 0 to 3) (default 0) -skip_threshold <int> E..V.... Frame skip threshold (from INT_MIN to INT_MAX) (default 0) -skip_factor <int> E..V.... Frame skip factor (from INT_MIN to INT_MAX) (default 0) -skip_exp <int> E..V.... Frame skip exponent (from INT_MIN to INT_MAX) (default 0) -skip_cmp <int> E..V.... Frame skip compare function (from INT_MIN to INT_MAX) (default dctmax) sad E..V.... Sum of absolute differences, fast sse E..V.... Sum of squared errors satd E..V.... Sum of absolute Hadamard transformed differences dct E..V.... Sum of absolute DCT transformed differences psnr E..V.... Sum of squared quantization errors, low quality bit E..V.... Number of bits needed for the block rd E..V.... Rate distortion optimal, slow zero E..V.... Zero vsad E..V.... Sum of absolute vertical differences vsse E..V.... Sum of squared vertical differences nsse E..V.... Noise preserving sum of squared differences dct264 E..V.... dctmax E..V.... chroma E..V.... -sc_threshold <int> E..V.... Scene change threshold (from INT_MIN to INT_MAX) (default 0) -noise_reduction <int> E..V.... Noise reduction (from INT_MIN to INT_MAX) (default 0) -mpeg_quant <int> E..V.... Use MPEG quantizers instead of H.263 (from 0 to 1) (default 0) -ps <int> E..V.... RTP payload size in bytes (from INT_MIN to INT_MAX) (default 0) -mepc <int> E..V.... Motion estimation bitrate penalty compensation (1.0 = 256) (from INT_MIN to INT_MAX) (default 256) -mepre <int> E..V.... pre motion estimation (from INT_MIN to INT_MAX) (default 0) -pred <int> E..V.... Prediction method (from 1 to 3) (default left) left E..V.... plane E..V.... median E..V....
how to improve speed encoding ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 2nd Feb 2016, 14:20 -
How can improve speed of ffmpeg encoding?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2015, 11:17 -
FFMPEG encoding mjpeg with "No Interleave" option?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 12th Dec 2013, 11:10 -
FFMPEG encoding MJPEG and CBR
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2013, 17:06 -
FFMPEG: from .mxf to mjpeg encoding
By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 11th Jul 2013, 16:52
