Hi, I have an mp4/m4v file that contains internal CEA-608 closed caption subtitles in English, but I would like to extract these into an external text file so that I can then translate them into Swedish (just for personal use, no commercial purpose) and then import them into the video again as a normal .srt file.
When I use Subler, it does recognize the subtitles, but it doesn't support exporting them into an .srt file for further editing. A few other applications also do acknowledge their existence, but neither of these support exporting them (I have even tried "ffmpeg -i file.mp4 -vn -an -codec:1.2 srt file.srt" in Terminal, but that doesn't work either).
Does anyone know of a way to get the CEA-608 extracted into an srt file -- on a Mac? I know there are some Windows applications like CCExtractor GUI that might be able to do this, but I'm afraid that is not of much use to me... Thanks for input/feedback on this!
/Mark
All I could find for ffmpeg was the command line below, but it only works for ts files. You will have to move the video from the mp4 file to a ts file to try it. ffmpeg can do that too.
I found the information at http://stackoverflow.com/questions/3169910/can-ffmpeg-extract-closed-caption-data There is an explanation from "ColdLearning" there, dated Aug 26 at 20:32.Code:ffmpeg -f lavfi -i movie=input.ts[out+subcc] -map 0:1 output.srt
If it doesn't work, you had better ask a friend running Windows if you can borrow his PC so you can try CCExtractorGUI or eac3to.Last edited by usually_quiet; 13th Sep 2016 at 12:54.
Try run with windows "emulator" wine
Can't extract audio from MP4 file
By Alonshow in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2016, 19:01 -
How to Get SRT Subtitle File To Print on MP4 from Handbrake?
By pone44 in forum Video ConversionReplies: 14Last Post: 15th Mar 2015, 14:29 -
Adding hard subtitles (.srt) to .mp4 file
By djc314 in forum MacReplies: 13Last Post: 8th Dec 2013, 10:13 -
How to extract .srt from mkv file
By Wooody in forum SubtitleReplies: 13Last Post: 18th Oct 2012, 06:43 -
How can i encode and add srt subtitles to 720p mp4 file?
By soshipurpleskies in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2012, 17:21
