...as seems to be the case in most circs, when any future DVD player plays it back and restores the picture to its original 16:9, is there "quality loss'? I mean, will this "restored" 16:9 look worse than the footage would've looked had it been copied to, say, a DVD-R and retained its original 16:9 aspect ratio?
PS It's the DMR-DWT720 model btw.
PAL DVD recorders record at 720:576 (5:4) or less (352x576 or 352x288, depending on recording speed). So neither 4:3 nor 16:9 content is ever recorded at the display aspect ratio.
Whether 720x576 can capture all the resolution of your source depends on the source. Terrestrial and satellite broadcast, whether 4:3 or 16:9, is often at 540x576 or even lower.Last edited by jagabo; 12th Sep 2016 at 11:23.
Sorry, let me be more precise - widescreen material copied from a camcorder not PAL TV stuff.
What kind of camcorder? You're obviously going to lose resolution if you're talking about a high def camcorder. If it's digital SD it probably uses the same frame size as DVD. If it's analog it probably lower resolution than DVD horizontally.
Panasonic 3D 4K 2TB Blu-Ray Recorder Do I need HD Fury?
By ezcapper in forum Capturing and VCRReplies: 14Last Post: 1st Nov 2016, 18:20 -
Recording in DR mode on Panasonic DMR-BWT955 Blu-ray recorder
By Ducatiman39 in forum Blu-ray RippingReplies: 10Last Post: 8th Feb 2016, 10:14 -
pioneer blu ray burner -want to make 1:1 copies of my blu ray movies
By Cool joe in forum MacReplies: 10Last Post: 10th Dec 2014, 22:31 -
panasonic hd blu ray recorder nothing converts them can you help
By geoff m in forum DVD & Blu-ray RecordersReplies: 22Last Post: 26th Nov 2013, 17:31 -
Blu-Ray burner wont recognize my Blu-Ray disc, Only DvD dics?
By PurkkaPoika in forum Authoring (Blu-ray)Replies: 5Last Post: 10th Jul 2012, 15:26
