    Sep 2016
    Bahrain
    so i got my samsung gear vr and i have downloaded some videos for gear vr 180/360 degree , some of those videos arent suported with the video or audio format (not sure) so whenever i convert it into a supported format the video runs but its either split screen side by side or the other way around.
    so kindly asking if there is a special decoder or converter for the Gear VR or a 3D converter.
    would appreciate any help and thanks in advance!
  2. Member Cornucopia's Avatar
    Not clear at all....
    There are multiple formats of VR and there are multiple formats of 3D, and not all 3D is VR nor vice-versa.
    Please state which format(s) you have (technical details!) and which you want (and how you want to view it), or better yet, post an original copy of one/some of your source material.
    Use exact model #s, MediaInfo info, etc. The more clear detail the better.
    Jan 2007
    converted video is never going to look 'right' on a PC
    or
    do you mean it does not look right on the VR gear
    VR is meant to have a 3d effect but also an immersive effect
    the motion detector in the gear, controls the panning motion of turning the view when your head turns
    normal ? 3d movies for BluRay playback, do not do that, should not do that,
