I have a load of old VHS tapes lying in my cupboard i want to check through, by fast forwarding through them all, as im sure there's lots with nothing on them and need to throw out. I just bought a Panasonic NV-HS860 for capturing, but with in not wanting to wear the heads, could i use my previous machine (a Bush DVRHS02) to check through them all since the heads are already worn on that model anyway, and if so will playing them on this machine damage my tapes?
				Results 1 to 11 of 11
	Buy a copy of some prerecorded trash vhs from a garage sale/thrift store for a $1 each and test them first to see if the player is ruining tapes or not.
	Run the tapes in FAST FORWARD and watch the tape counter. It won't advance if there's nothing recorded. This operation doesn't put any wear on the video heads.
	Maybe I'm missing something but what advances the tape counter when you fast forward? Wouldn't the tape have to be in contact with the read heads in order for it to "know" if there's anything recorded - so as to advance the counter or not? Rich
	Well i put in a retail video i was going to throw out anyway and test that it works. Unfortunately it sort of got chewed up when it was rewinding itself, so i had to stop the machine, open it up and take it out, in case it was wrapped round any parts, but was just stuck behind the winding spool. Now i don't know if this was because that tape was dodgy, as it was squeaking in my other machine, but i did clean the heads inside my old machine earlier in the year, and cleaned off what looked like green marker pen on the metal base inside. But i now realise this was supposed to be there? Is that to grease the parts so they'll move smoothly and the rewinder has not moved to the right place, hence why the tape unraveled?
	I'm not sure what you mean by "rewinder," but there are a couple of tape guides that travel in slots between the cassette and the video drum. Those slots should be lightly greased along their top edges. I use a synthetic grease called Super Lube.
	Yeah the tape guides, forgive me for not being clued up about the parts inside lol. Thanks for that, i'll order it now. Would you just apply it with your finger along the slot edges then?
	A cotton bud makes a tidier application. Make sure the surfaces are clean first and then apply a very small amount. Keep the grease away from any rubber parts.
  I need some help converting my old VHS, VHS-C, and 8mm/Hi8 tapes. Many Q's!By CZbwoi in forum Capturing and VCRReplies: 80Last Post: 20th Apr 2016, 17:17
  vhs tapesBy jamespoo in forum Capturing and VCRReplies: 2Last Post: 25th Mar 2013, 01:05
  Checking my DVD player's aspect ratioBy fvisagie in forum DVD & Blu-ray PlayersReplies: 51Last Post: 20th Mar 2013, 03:47
  Is it possible to use an SVHS VCR as a player for standard VHS tapes?By TrackingError in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2013, 00:31
  Best UK PAL VHS / D-VHS machines for digitising old VHS tapesBy pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
