Page 2 of 3
FirstFirst 1 2 3 LastLast
Results 31 to 60 of 62
  1. DECEASED
    Jun 2009
    Heaven
    Is https://www.leaseweb.com/nl/ slow?
    I haven't noticed any server problems in several years...and have same web host for several years.
    Yep, leaseweb.com is slow, and Videohelp is even slower
  2. Member hydra3333's Avatar
    Oct 2009
    Australia
    Hello, I'm sitting here with an i7-3820 PC (with not much installed) connected with 100Mbps connection. Using Chrome, Firefox, IE. I do notice huge slowdowns and loading issues on videohelp. I'm located in Australia.
    ping -a www.videohelp.com
    Pinging www.videohelp.com [85.17.24.140] with 32 bytes of data:
    Reply from 85.17.24.140: bytes=32 time=337ms TTL=41
    Reply from 85.17.24.140: bytes=32 time=319ms TTL=41
    Reply from 85.17.24.140: bytes=32 time=322ms TTL=41
    Ping statistics for 85.17.24.140:
        Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
        Minimum = 319ms, Maximum = 337ms, Average = 324ms
    Yes, slightly slow, it looks to be a smallish page though, however it isn't slow to the scale of visiting videohelp.com.
    ping -a www.leaseweb.com
    Pinging d4865badf01ed65dfe4d6a718f62671e.60680ad5728991c31277cd43f733903d.net [103.254.152.5] with 32 bytes of data:
    Reply from 103.254.152.5: bytes=32 time=148ms TTL=45
    Reply from 103.254.152.5: bytes=32 time=132ms TTL=45
    Reply from 103.254.152.5: bytes=32 time=131ms TTL=45
    Ping statistics for 103.254.152.5:
        Minimum = 131ms, Maximum = 148ms, Average = 135ms
  3. Member hydra3333's Avatar
    Oct 2009
    Australia
    deleted double post
  4. Member hydra3333's Avatar
    Oct 2009
    Australia
    Hmm. Lots of timeouts out at videohelp's end - although Telstra is slow, videohelp.com does not look to be behaving "normal".
    tracert -4 www.videohelp.com
    Tracing route to www.videohelp.com [85.17.24.140]
    over a maximum of 30 hops:
      1    <1 ms    <1 ms    <1 ms  192.168.0.1
      2     9 ms     8 ms     7 ms  10.251.0.1
      3     8 ms     9 ms     7 ms  CPE-58-160-25x-x.wa.bigpond.net.au [58.160.25x.x]
      4     9 ms    15 ms    11 ms  bundle-ether4.fli-edge901.adelaide.telstra.net [203.50.116.100]
      5    15 ms     7 ms    11 ms  bundle-ether8.fli-core1.adelaide.telstra.net [203.50.11.154]
      6    19 ms    21 ms    23 ms  bundle-ether9.win-core10.melbourne.telstra.net [203.50.11.91]
      7    35 ms    31 ms    32 ms  bundle-ether12.ken-core10.sydney.telstra.net [203.50.11.122]
      8    32 ms    31 ms    42 ms  bundle-ether1.pad-gw11.sydney.telstra.net [203.50.6.61]
      9    30 ms    29 ms    40 ms  bundle-ether1.sydp-core04.sydney.reach.com [203.50.13.90]
     10   192 ms   187 ms   187 ms  i-0-1-0-5.tlot-core01.bx.telstraglobal.net [202.84.136.201]
     11   175 ms   178 ms   176 ms  i-0-4-0-1.tlot02.bi.telstraglobal.net [202.84.251.150]
     12   254 ms   253 ms   262 ms  leaseweb-network-b.v.as16265.any2ix.coresite.com [206.72.210.213]
     13   237 ms   238 ms   233 ms  te-7-2.bb02.wdc-01.leaseweb.net [217.20.125.40]
     14     *        *        *     Request timed out.
     15     *        *        *     Request timed out.
     16     *        *        *     Request timed out.
     17   322 ms   318 ms   318 ms  videohelp.com [85.17.24.140]
    Trace complete.
  5. Member hydra3333's Avatar
    Oct 2009
    Australia
    www.leaseweb.com appears to be timing out too ...
    tracert -4  www.leaseweb.com
    Tracing route to d4865badf01ed65dfe4d6a718f62671e.60680ad5728991c31277cd43f733903d.net [103.254.152.8]
      2    12 ms     7 ms    17 ms  10.251.0.1
      3    14 ms     9 ms     7 ms  CPE-58-160-25x-x.wa.bigpond.net.au [58.160.25x.x]
      4     8 ms     9 ms     7 ms  bundle-ether4.fli-edge901.adelaide.telstra.net [203.50.116.100]
      5    11 ms    11 ms     7 ms  bundle-ether8.fli-core1.adelaide.telstra.net [203.50.11.154]
      6    41 ms    44 ms    39 ms  bundle-ether5.wel-core3.perth.telstra.net [203.50.11.19]
      7    49 ms    35 ms    35 ms  tengige0-8-0-5-1.pie-core1.perth.telstra.net [203.50.6.198]
      8    37 ms    48 ms    37 ms  tengige0-5-1-0.pthp-core01.perth.net.reach.com [203.50.13.254]
      9    88 ms    87 ms    84 ms  i-0-5-4-0.skdi-core01.bx.telstraglobal.net [202.84.143.181]
     10    86 ms    85 ms    85 ms  i-0-5-0-7.istt04.bi.telstraglobal.net [202.84.243.2]
     11     *        *        *     Request timed out.
     12   133 ms   132 ms   131 ms  xe-1-2-0.ce01.sin-10.sg.leaseweb.net [103.254.152.205]
     13   131 ms   131 ms   131 ms  103.254.152.133
     14   134 ms   133 ms   133 ms  103.254.152.8
    Trace complete.
      2     8 ms     7 ms     7 ms  10.251.0.1
      3     8 ms     9 ms     7 ms  CPE-58-160-25x-x.wa.bigpond.net.au [58.160.251.x]
      4     9 ms     9 ms    13 ms  bundle-ether4.fli-edge901.adelaide.telstra.net [203.50.116.100]
      5    10 ms    11 ms    11 ms  bundle-ether8.fli-core1.adelaide.telstra.net [203.50.11.154]
      6    41 ms    39 ms    39 ms  bundle-ether5.wel-core3.perth.telstra.net [203.50.11.19]
      7    36 ms    39 ms    39 ms  tengige0-8-0-5-1.pie-core1.perth.telstra.net [203.50.6.198]
      8    36 ms    35 ms    36 ms  tengige0-5-1-0.pthp-core01.perth.net.reach.com [203.50.13.254]
      9    85 ms    87 ms    87 ms  i-0-5-4-0.skdi-core01.bx.telstraglobal.net [202.84.143.181]
     10    85 ms    91 ms    92 ms  i-0-5-0-7.istt04.bi.telstraglobal.net [202.84.243.2]
     12   133 ms   133 ms   131 ms  xe-1-2-0.ce01.sin-10.sg.leaseweb.net [103.254.152.205]
     13   138 ms   131 ms   131 ms  103.254.152.133
    Trace complete.
  6. Member hydra3333's Avatar
    Oct 2009
    Australia
    removed double post
    Feb 2004
    Australia
    hydra3333
    Check with telstra and confirm if ip is static or not ... if static get them to change it.
    If not static then like I used to try releasing it (turn unit off for 4 minutes) then back on to check ip assignment, it might take a couple of tries to get assigned a different ip range ... sometimes, not often I'd leave off till next day.
  8. Member hydra3333's Avatar
    Oct 2009
    Australia
    Thanks. Cable modem is set to dchp, so it's a dynamic IP, unless there's a reservation at the Telstra end (which would be unusual, it's a dhcp plan).
    Yes, have done both of those, unsuccessfully, including two courtesy of an electricity outage in my state
    I'll try again.
    edit: tried again, the dhcp leases must be long lived as the IP is unchanged.
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the part timing out isn't at your end. a different ip at your house won't help. it's the hop between leaseweb and videohelp. some script kiddies might be doing denial of service attack or their routers are just on the fritz at leaseweb.
  10. DECEASED
    Jun 2009
    Heaven
    It seems the companies who use the DOCSIS technology make the dynamic IP addresses "live" for much longer than the companies who use ADSL/VDSL technology. Different from what happens with a DSL router, turning off + turning on a cable modem does not cause an immediate change in the assigned IP address
  11. Member hydra3333's Avatar
    Oct 2009
    Australia
    Thanks, that's what I thought too after looking at the outputs from tracert ... the results are clear evidence that it is timing out at the videohelp end and it stands to reason that whatever is causing the issues could/should be fixed at that end ?
  12. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if it's hackers doing a denial of service attack, it will clear up when they decide to end it. they use distributed ip's that are hard to block.
  13. I'm a MEGA Super Moderator Baldrick's Avatar
    I could try contact leaseweb and see what they say.
    I have no timeouts from tracert to videohelp.com
      7    15 ms    15 ms    16 ms  netnod-ix-ge-b-sth-1500.leaseweb.com [194.68.128.160]
      8    36 ms    39 ms    39 ms  31.31.34.10
      9    37 ms    37 ms    35 ms  te-0-0-0-18.br02.ams-01.nl.leaseweb.net [31.31.38.45]
     10    39 ms    35 ms    34 ms  xe-5-3-1.cr04.ams-01.nl.leaseweb.net [81.17.33.39]
     11    40 ms    39 ms    39 ms  videohelp.com [85.17.24.140]
    Can you do a tracert to 94.75.217.78 also? Same problem?
  14. Member hydra3333's Avatar
    Oct 2009
    Australia
    Hello, sure :-
    tracert -4 94.75.217.78
    Tracing route to edvision.se [94.75.217.78]
      2    12 ms    11 ms    13 ms  10.251.0.1
      3    13 ms    13 ms    11 ms  CPE-58-160-25x-x.wa.bigpond.net.au [58.160.25x.x]
      4    12 ms    14 ms    13 ms  bundle-ether4.fli-edge901.adelaide.telstra.net [203.50.116.100]
      5    14 ms    16 ms    15 ms  bundle-ether8.fli-core1.adelaide.telstra.net [203.50.11.154]
      6    38 ms    27 ms    27 ms  bundle-ether9.win-core10.melbourne.telstra.net [203.50.11.91]
      7    39 ms    42 ms    38 ms  bundle-ether12.ken-core10.sydney.telstra.net [203.50.11.122]
      8    37 ms    38 ms    36 ms  bundle-ether1.pad-gw11.sydney.telstra.net [203.50.6.61]
      9    34 ms    42 ms    40 ms  bundle-ether1.sydp-core04.sydney.reach.com [203.50.13.90]
     10   191 ms   195 ms   207 ms  i-0-1-0-5.tlot-core01.bx.telstraglobal.net [202.84.136.201]
     11   193 ms   188 ms   191 ms  i-0-4-0-4.tlot02.bi.telstraglobal.net [202.40.149.166]
     12   254 ms   256 ms   252 ms  leaseweb-network-b.v.as16265.any2ix.coresite.com [206.72.210.213]
     13   267 ms   258 ms   251 ms  te-5-3.bb02.wdc-01.leaseweb.net [217.20.125.88]
     17   343 ms   350 ms   344 ms  edvision.se [94.75.217.78]
    Trace complete.
    Yep, same symptom at the leaseweb.net end of things.
    That would be handy, if you could.
    I am unlucky ... but surely not the only one on the planet seeing this symptom, both now and into the future
    It'd be good to know the cause and the fix.
  15. Member TuNk's Avatar
    Jul 2012
    Norway
    No problems here:
    1 1 ms 1 ms <1 ms 192.168.1.1
    2 34 ms 2 ms 7 ms sw001570.cdi.no [37.200.62.1]
    3 1 ms 4 ms 1 ms 195.134.46.113
    4 5 ms 3 ms 1 ms ti0021a400-ge1-2-3.ti.telenor.net [62.92.87.237]
    5 46 ms 12 ms 12 ms ti0300c360-ae54-0.ti.telenor.net [146.172.19.1]
    6 12 ms 12 ms 12 ms ti3163c360-ae8-0.ti.telenor.net [146.172.101.194]
    7 14 ms 12 ms 12 ms ti3001b400-ae3-0.ti.telenor.net [146.172.105.62]
    8 12 ms 12 ms 15 ms netnod-ix-ge-b-sth-1500.leaseweb.com [194.68.128.160]
    9 35 ms 31 ms 32 ms 31.31.34.10
    10 29 ms 27 ms 27 ms te-0-0-0-18.br02.ams-01.nl.leaseweb.net [31.31.38.45]
    11 27 ms 27 ms 27 ms te-4-1.ce21.ams-01.nl.leaseweb.net [81.17.32.235]
    12 29 ms 29 ms 29 ms edvision.se [94.75.217.78]
    Trace complete.
  16. I'm a MEGA Super Moderator Baldrick's Avatar
    Hello, sure :-
    Trace complete.
    Okey. Leaseweb answered. They want you to do a mtr bidirectional test, see https://kb.leaseweb.com/display/KB/Making+a+bidirectional+MTR
    From windows use : http://winmtr.net/how-to/ and use ip 85.17.24.140. At least 100 packets are required, and Resolve names must be turned off in the Options menu.
    From linux: mtr -n -r -c 100 85.17.24.140
  17. Member hydra3333's Avatar
    Oct 2009
    Australia
    OK, I'll get onto it.
    PS I asked on https://forums.whirlpool.net.au/forum-replies.cfm?t=2571711&p=-1 and at least one other person with a different ISP has the same issue.
  18. Member hydra3333's Avatar
    Oct 2009
    Australia
    OK, here you go. I've "x"d out the last bit of my external IP, let me know if you need it.
    |                                      WinMTR statistics                                   |
    |                       Host              -   %  | Sent | Recv | Best | Avrg | Wrst | Last |
    |                             192.168.0.1 -    1 |  229 |  227 |    1 |    2 |   13 |    1 |
    |                              10.251.0.1 -    0 |  236 |  236 |    8 |   16 |   46 |   16 |
    |                            58.160.25x.x -    1 |  229 |  227 |    9 |   15 |   34 |   10 |
    |                          203.50.116.100 -    1 |  229 |  227 |    9 |   16 |   43 |   16 |
    |                           203.50.11.154 -    1 |  233 |  232 |    9 |   17 |   60 |   18 |
    |                            203.50.11.91 -    1 |  229 |  227 |   19 |   27 |   55 |   24 |
    |                           203.50.11.122 -    1 |  233 |  232 |   30 |   39 |   66 |   36 |
    |                             203.50.6.61 -    1 |  233 |  232 |   31 |   39 |   69 |   38 |
    |                            203.50.13.90 -    1 |  233 |  232 |   30 |   39 |   66 |   32 |
    |                          202.84.136.201 -    1 |  229 |  227 |  186 |  193 |  220 |  192 |
    |                          202.84.251.150 -    1 |  229 |  227 |  175 |  183 |  204 |  176 |
    |                          206.72.210.213 -    1 |  233 |  232 |  251 |  261 |  346 |  255 |
    |                           217.20.125.40 -    2 |  225 |  222 |  232 |  245 |  584 |  234 |
    |                   No response from host -  100 |   48 |    0 |    0 |    0 |    0 |    0 |
    |                            85.17.24.140 -    0 |  236 |  236 |  319 |  326 |  362 |  326 |
    |________________________________________________|______|______|______|______|______|______|
       WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
    Tracing route to edvision.se [94.75.217.78] over a maximum of 30 hops:
    Trace complete.
    Just FYI, that's a typical tracert.
    The timeout is internal Leaseweb network, and not unusual, nor does it reveal a problem.
    The latency appears typical as well, for non-EU connection.
    When I tracert, I get Telia to the Leaseweb network edge, then don't get another IP result until this site's server.
    The issue probably lies between Australia and Europe. BTW, that's a lot of on-continent hops.
  20. I'm a MEGA Super Moderator Baldrick's Avatar
    |                                      WinMTR statistics                                   |
    Thanks. I will forward it and see if they know why it's slow from your connection.
  21. Member hydra3333's Avatar
    Oct 2009
    Australia
    Thanks. No doubt the Telstra techs are doing their best ... it does seem like quite a lot of Telstra-internal hops, doesn't it
    Given other feedback, unless another Aus ISP uses Telstra infrastructure for "connection" at the Aus end of things then it maybe looks like a routing issue possibly at leaseweb's end ?
  22. I'm a MEGA Super Moderator Baldrick's Avatar
    Leaseweb could'nt find any network problems.
  23. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    from the usa there is a weird loop in the tracert. signal path goes from usa to nl back to the usa and then forwarded back to nl. yayo.com seems to be the holdup here.
  24. Video Restorer lordsmurf's Avatar
    I don't think that image matches the route.
    It doesn't appear to.
    And I don't think this is a Leaseweb issue.
  25. Member hydra3333's Avatar
    Oct 2009
    Australia
    OK. Well, , this post https://forums.whirlpool.net.au/forum-replies.cfm?t=2571711#r2 seems to indicate that's 3 major Aus ISP's (Telstra, iinet, Optus) who have users "affected".
    It loaded very slowly for me on Internode ADSL2+ and Optus mobile broadband.
    I work way down the hall from some network guys, and the stuff they saw and complained about in relation to their large network service providers over the years always made me smile (by virtue of my not having to deal with it).
  26. Member hydra3333's Avatar
    Oct 2009
    Australia
    removed double post. damn it, i must remember not to post when for whatever reason a page hasn't finished loading.
  27. Member hydra3333's Avatar
    Oct 2009
    Australia
    Just watched it again, and when loading the home page "https://www.videohelp.com/" it waited for minutes stuck on the message "Waiting for p.skimresources.com...", then more minutes with "Waiting for t.skimresources.com...".
    Funnily enough ... now ... with other pages, eg forum pages, it loads normally in terms of elapsed time.
    Go figure.
    Cheers
    edit: 1 Well, this is looking like a possible culprit given each timeout takes a fair while, and when taken in conjunction with the browser messages above :-
    tracert -4 p.skimresources.com
    Tracing route to p.skimresources.com [52.87.136.213]
      2     *        *        *     Request timed out.
      3    10 ms    12 ms    12 ms  CPE-58-160-25x-xxx.wa.bigpond.net.au [58.160.25x.xxx]
      4    12 ms    12 ms    12 ms  bundle-ether4.fli-edge902.adelaide.telstra.net [203.50.116.106]
      5    15 ms    15 ms    16 ms  bundle-ether9.fli-core1.adelaide.telstra.net [203.50.11.150]
      6    21 ms    23 ms    24 ms  bundle-ether9.win-core10.melbourne.telstra.net [203.50.11.91]
      7    34 ms    33 ms    35 ms  bundle-ether12.ken-core10.sydney.telstra.net [203.50.11.122]
      8    35 ms    35 ms    33 ms  bundle-ether1.pad-gw11.sydney.telstra.net [203.50.6.61]
      9    32 ms    31 ms    31 ms  bundle-ether1.sydp-core04.sydney.reach.com [203.50.13.90]
     10    34 ms    34 ms    35 ms  i-0-1-0-47.sydp-core03.bi.telstraglobal.net [202.84.222.25]
     11   177 ms   175 ms   175 ms  i-41.traglobal.bx.telstraglobal.net [202.84.136.38]
     12     *      177 ms   178 ms  i-0-4-0-1.eqla01.bi.telstraglobal.net [202.84.251.154]
     13   175 ms   175 ms   175 ms  los-brdr-01.inet.qwest.net [63.235.40.45]
     15   243 ms   242 ms   243 ms  72.165.86.90
     17     *        *        *     Request timed out.
     18   260 ms   246 ms   247 ms  54.239.110.199
     19   253 ms   255 ms   256 ms  54.239.109.179
     20   254 ms   255 ms   252 ms  72.21.222.129
     21     *        *        *     Request timed out.
     22     *        *        *     Request timed out.
     23     *        *        *     Request timed out.
     24     *        *        *     Request timed out.
     25     *        *        *     Request timed out.
     26     *        *        *     Request timed out.
     27     *        *        *     Request timed out.
     28     *        *        *     Request timed out.
     29     *        *        *     Request timed out.
     30     *        *        *     Request timed out.
    Trace complete.
    tracert -4 t.skimresources.com
    Tracing route to t.skimresources.com [54.193.47.182]
      3    12 ms    12 ms    12 ms  CPE-58-160-25x-xxx.wa.bigpond.net.au [58.160.25x.xxx]
      5    13 ms    11 ms    11 ms  bundle-ether9.fli-core1.adelaide.telstra.net [203.50.11.150]
      6    22 ms    20 ms    22 ms  bundle-ether9.win-core10.melbourne.telstra.net [203.50.11.91]
      7    32 ms    31 ms    32 ms  bundle-ether12.ken-core10.sydney.telstra.net [203.50.11.122]
      8    34 ms    34 ms    35 ms  bundle-ether1.pad-gw11.sydney.telstra.net [203.50.6.61]
      9    35 ms    33 ms    31 ms  bundle-ether1.sydp-core04.sydney.reach.com [203.50.13.90]
     10   182 ms   177 ms   170 ms  i-12.paix-core01.bx.telstraglobal.net [202.84.136.194]
     11   167 ms   169 ms   169 ms  i-0-0-0-1.paix02.bi.telstraglobal.net [202.84.251.74]
     12   168 ms   169 ms   169 ms  unknown.telstraglobal.net [134.159.61.137]
     13     *        *        *     Request timed out.
     15   168 ms   169 ms   168 ms  72.21.222.19
     18     *        *        *     Request timed out.
     19     *        *        *     Request timed out.
     20     *        *        *     Request timed out.
    Trace complete.
    edit 2: And, now I've also got a new IP from Telstra ... 58.160.75.xxx
  28. I'm a MEGA Super Moderator Baldrick's Avatar
    Go figure.
    Cheers
    Trace complete.
    Trace complete.
    Didn't you try turn of javascript? Then shouldn't skimresources load. But it's added to the bottom of the code so it shouln't really stop the page from loading.
  29. I'm a MEGA Super Moderator Baldrick's Avatar
    Can you access http://s.skimresources.com/js/19619X769413.skimlinks.js ?
    I have now tried replace the javascript with a local javascript. DOes it still stop the page from loading?
  30. Member hydra3333's Avatar
    Oct 2009
    Australia
    Close enough to instantly displays as text
    Thanks for persisting. Progress, of sorts. As of just 5 minutes ago, using Chrome
    - it took forever to load the main page, other pages were very fast
    - turned off javascript (browser still open) and the main page was very quick
    - cleared cache (browser still open) and the main page was very quick then turned on javascript
    - closed and opened browser and the main page went fast past p.skimresources.com but is now slow as wet whistle and "stuck" on t.skimresources.com
    A tad baffling but there you go.
    Tried firefox, similar behaviour.
    Cheers
