Results 1 to 12 of 12
  1. Hi guys,
    I'm trying to convert Blu-ray with subtitles to the TS format and keeping the subtitles (not embedded or as a separate file but as DVB subtitles).
    Anyone know of a software that can do this?
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Might give tsMuxeR a try.
  3. Originally Posted by KarMa View Post
    I've looked at that but it seems to only work by selecting single files to convert as opposed to a full Blu-ray
  4. DECEASED
    Jun 2009
    Heaven
    eac3to should be able to read a (decrypted) Blu-Ray directory and demux it to elementary streams.
    Then you can remux these with TSmuxer, or maybe with ffmpeg...
    Does Blu-Ray support DVB subtitles
  5. Originally Posted by El Heggunte View Post
    No but I need to convert the Blu-ray subtitles to DVB subtitles while also converting the video and audio.
  6. In theory ffmpeg is capable to convert PSG to DVD sub (almost same thing as DVB sub) however when i tried to convert BD sub to DVD sub no errors was reprted but file was or without visible subtitles or unplayable.
    Problem with BD sub file format is 256 vs 4 colors on DVD/DVB (ffmpeg implementation).
    There are some separate application to convert BD sub to other formats but never tried them.
  7. Originally Posted by pandy View Post
    That isn't exactly what I need. I need to convert Bluray content to a proper DVB TS file and a proper TS file will also contain a subtitle PID within itself and NOT a separate subtitle file like .srt etc.
  8. DECEASED
    Jun 2009
    Heaven
    pandy wrote nothing about "separate subtitle files", he wrote:
    ``There are some separate application to convert BD sub to other formats but never tried them´´
    Okay, English is not his native language (and it's not mine either), but I doubt that that's the cause of your misunderstanding
    As for ffmpeg (OR ffmbc) — IF it doesn't have proper support for DVB subs, then you'll have to use some commercial TS multiplexer, I'm afraid.
  9. Never tried this before but..
    Made a clip from a MKV generated with MakeMKV from a Blu-ray.
    Extracted the PGS subtitles with MKVCleaver. Muxed a copy of the clip without subtitles. Converted PGS to idx/vobsub with BDSup2Sub++. Used ffmeg:
    ffmpeg -i video.mkv -i subtitle.sub -vcodec copy -acodec copy -scodec dvbsub out.ts
    The dvdsub is recognised in MediaInfo and can be used in VLC - may need some work on the coloring.
  10. Originally Posted by El Heggunte View Post
    Ok sorry Pandy!
  11. Originally Posted by lazareth1 View Post
    Ok sorry Pandy!
    lol no problemo - sorry for my English - it is exactly like El Heggunte wrote - not my native and self learned...
  12. Originally Posted by videobruger View Post
    [Attachment 38535 - Click to enlarge]
    [Attachment 38536 - Click to enlarge]
    Seems to work for me videobruger thanks! The timing and colour was off just like yours. I fixed this by using the idx file which contains the missing data
