Hi all
I need some help as I have run into a weird issue that is probably easy to fix if you know how.
I am editing together my daughter's "first year of life" video clips that we've taken. I have the following formats:
.MOV - taken with my iPhone 6 - H.264 1920x1080x24
.MTS - taken with a Sony Bridge Camera, these are the majority of the clips - AVC 1920x1080x12
.MP4 - taken with my wife's MOTO G - AVC 1920x1080x12
Now, all of these clips play absolutely fine on my PC when double clicked and VLC Player runs them.
When I have imported them into my video project, the MTS videos play file. The MOV files play very slowly (although the audio sounds fine) and the MP4 files are super choppy (imagine a bad stream over the internet) but again audio is fine. I am using Sony Movie Studio Platinum
I thought maybe the mix of formats was the issue, so I created a new project with just the MP4 in, and then just the MOV in- same issue. When I render it out (thought maybe it was project preview causing issues), same issue.
Can anyone perhaps explain this, is it a fps thing? Or perhaps point me in the right direction?
Many thanks in advance
Latest movie studio 13 ?
So the preview AND output has same issues? -
i'd try converting the ones that don't play well with ms12 to a lossless format before using them in a project. install the UTcodec and use ms12 to render them out. then import them all into your project. you'll need a lot of hard drive space but then everything should play together fine.
Personally, I'd convert them ALL to lossless, to make all of them easier/more fluid to edit.
And I'd make them have the same common frame size and framerate (doubling if necessary).
THEN edit.
Then export to lossless master, then convert to final formats (h264-mp4, mpg2-dvd, etc) it will be viewed in.
Scott -
Thanks everyone, with some experimentation I have converted them all and now they preview and render correctly- many thanks
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 10:27 -
Old Video Formats Help
By Velhans in forum Video ConversionReplies: 8Last Post: 28th Jun 2015, 20:29 -
HD formats support - Pro editing softwares comparative board
By Turmap in forum EditingReplies: 19Last Post: 30th Dec 2014, 18:01 -
Convert multiple formats to one format for editing?
By swjtx99 in forum Newbie / General discussionsReplies: 6Last Post: 20th Jun 2013, 11:27 -
Video Formats
By andyf in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2011, 04:10
