Is there a free piece of software that i can rip from history or discovery channel? Possibly abc? What website has the cartoon "the archies tv funnies and show on it? John
For ABC you can use ChrisPC Free VideoTube Downloader, don't know if the other sites work with this version, but should work with the PRO version:
http://downloadvideo.how/video-downloader/abc-go-com-download-videos-tv-series.html -
Hi i tried ChrisPC Free Downloader Pro but it didn't worked for me correctly. Said use "Link Finder" but it isn't finding any link. Also the video don't start when accessing a normal stream on abc.go.com (in link finder and normal browser). Has someone also accessing the webpage/streams?
Maybe you don't have the right Flash player in Link Finder, check this on their forum: http://forum.chris-pc.com/viewtopic.php?f=20&t=8944
Solved the issues. Flash wasn't working correctly. After reinstalling everthing worked.
Downloading or Copying Video From History Channel?
By brispuss in forum Video Streaming DownloadingReplies: 23Last Post: 8th Jun 2017, 00:06 -
How to re-edit a single channel on DTS audio 6 channel
By maisawka in forum EditingReplies: 7Last Post: 26th Jun 2014, 11:55 -
converting 6 channel audio to 2 channel & putting 2 streams in a container
By qorda in forum AudioReplies: 3Last Post: 14th Jan 2014, 03:43 -
Converting 6 channel audio to 2 channel stereo- Help needed
By drashkum in forum AudioReplies: 2Last Post: 7th Sep 2013, 23:33 -
firefox history - where is the complete history ?
By vhelp in forum ComputerReplies: 8Last Post: 20th May 2013, 07:31
