I'm battling to get My Philip CED750 DVD player to work anyone have procedure to reset the Regional Code settings
Most cannot be changed. And even then it's usually on or off (ie: region free).
Are you sure you are having a region code issue?Google is your Friend -
I'm quite sure its a Regional Code issue for both CD's and DVD's and would be very happy if I could just turn the Regional Code function off
Yes it is a car player have it setup in My mobile campervan
When I purchased it 6 years ago it was programmed for Our Region it's stood some years and batteries in RV have been changed and factory reset done to unit , original installer has retired so I know it did work so hoping someone can come up with a plan
Be that as it may, there is no hack to be found here at VideoHelp. There is only one for a different model. https://www.videohelp.com/dvdhacks/philips-ced780/12413
Service personnel are very often the only people with access to the information you want, assuming it exists. Find a different installer or a Philips service center and ask them if they can modify your player's settings.
Regional code LG HT552TH
By LisaRas in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Feb 2015, 10:16 -
Reset of Video on Harman Kardon DVD 506 Player.
By keithsloan52 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 28th Mar 2014, 16:00 -
Protron DVD player PD-007 in Progressive mode How do I reset.
By joe347 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 25th Nov 2013, 20:36 -
Regional Code 2 played in zone 1
By Miatudello in forum DVD & Blu-ray PlayersReplies: 9Last Post: 1st Oct 2013, 16:30 -
DVD Player regional codes
By jazzman25 in forum Newbie / General discussionsReplies: 7Last Post: 1st Apr 2013, 14:06
