This seems so simple, but I can't make it work. I've tried AVS video editor and convertor and also handbrake.
It seems it will work if I apply the rotate and zoom effect in AVS, but the problem is the rotate turns it into this very small video in center of screen, so when I use the zoom effect, it becomes pixelated.
The annoying part is that I'm not even sure the video needs to be rotated. It lists the resolution as 1920x1080 in windows and when I play the file in MPC, it looks fine, but if I play in VLC or I try to edit the file in AVS or Camtasia, the aspect ratio is inverted.
Results 1 to 12 of 12
If the picture is sideways and you want it right side up, you'll have to rotate the video. You can't turn a 9:16 video into a 16:9 video without shrinking it and adding borders, or cropping and zooming, or some combination of the two.
Now you know not to shoot video with your phone held vertically. -
AndroidIphone video?
What software should I use to rotate the video without much degradation? The AVS video editor creates a very pixelated video after rotation. Is there anything better?If the picture is sideways and you want it right side up, you'll have to rotate the video. You can't turn a 9:16 video into a 16:9 video without shrinking it and adding borders, or cropping and zooming, or some combination of the two.
It displays perfectly in MPC (media player classic) without any manipulation. If MPC can just play it correctly like that, then what is going on with the encoding? Could the file somehow be altered to just force it to play correctly?
I don't know anything about avs video editor. If it has options for the resize filter you might be able to pick a sharper one. Typical resizing filters include (from least sharp to most sharp): bilinear, bicubic, lanczos. Or if it gives you a separate sharpening filter you can try using that. But keep in mind that sharpening, whether in the resizer or a separate filter, will exacerbate any blocky artifacts in your source.
I did it with MPEG StreamClip freeware (Edit -> Rotate Video and I then I used File -> Export to MPEG-4 in stead of Save As).
I had a Vertical Video from my iPhone and I cropped some part of it on my PC. The result was a rotated video, making it annoying to watch if I would mail it to somebody else who would play it on a mobile phone.
So I used MPEG StreamClip to rotate the cropped video and it played perfectly vertical, both on Windows Media Player in a vertical window and on my iPhone, full screen in normal vertical position).
Another option I used in the past was www.videorotate.com where you can upload you horizontal video and download a vertical version of it, for free. -
please look at dates when responding, this is dead 19 month old topic
Totally agree. Very disappointing that nobody came up with a free solution in all those 19 months and all this time vertical videos are becoming more and more popular.
I just found yet another free solution: DVDVideosoft - Free Video Flip and Rotate v 2.2.41
Works like a charm.
Cheers -
until TV and movie screens switch to vertical
taking vertical movies with cellphone is stupid and annoying
too get full screen you have to crop out way too much of the video frame
because it is going to be displayed on a horizontal screen, if viewed on PC, TV, etc..
everything is 'wide screen' not 'high screen', even most mobile gaming, and all PC gaming
holding the phone vertical for video is a 'lazy habit' from texting
people who used a camera before owning a cellphone, naturally hold it horizontal (the right way) when taking videos and pictures, unless doing portraits
its called landscape mode and has been the default normal mode for 150 yrs
How change aspect ratio of video before burning?
By VenusAndMars in forum Video Streaming DownloadingReplies: 11Last Post: 7th Jul 2016, 02:21 -
How to Change Video Aspect Ratio
By Aashik Alam in forum Video ConversionReplies: 7Last Post: 5th Jan 2016, 04:00 -
how to change video aspect ratio in m2v file
By krishnakumar684 in forum EditingReplies: 22Last Post: 5th Jan 2014, 12:20 -
Rotate and Convert to VOB without destroying aspect ratio?
By nerys in forum Video ConversionReplies: 20Last Post: 25th May 2012, 10:32 -
Cannot change a video's display aspect ratio, why?
By ericdunn in forum Newbie / General discussionsReplies: 22Last Post: 25th May 2012, 00:38
