  1. Friends
    Im so unhappy and frustrated. I have been trying to burn the blu ray files(BDMV and Certificate) folders on to blank disks for the past 2 weeks. Last week I tried with Samsung blu ray burner and 9 out of 10 disks failed burning.
    I purchased the asus turbo drive external blu ray burner and tried to burn it with nero, dvd fab and img burn and all the 3 disks failed.
    Media being used is 50GB dual layer original Verbatim disks.
    OS is Windows 7 64 bit. Im pasing the logs below(2 logs, one few days back and the latest one just now).
    What could be wrong? Please help friends.
    ;   ImgBurn Version 2.5.8.0 - Log
    ;   Wednesday, 07 September 2016, 22:05:50
    I 21:10:50 ImgBurn Version 2.5.8.0 started!
    I 21:10:50 Microsoft Windows 7 Home Basic x64 Edition (6.1, Build 7601 : Service Pack 1)
    I 21:10:50 Total Physical Memory: 4,098,104 KiB  -  Available: 1,394,124 KiB
    I 21:10:50 Initialising SPTI...
    I 21:10:50 Searching for SCSI / ATAPI devices...
    I 21:10:52 -> Drive 1 - Info: TSSTcorp DVD+-RW SN-208BB D300 (E:) (SATA)
    E 21:10:52 DeviceIoControl(IOCTL_USB_GET_NODE_CONNECTION_INFORMATION_EX) Failed!
    E 21:10:52 Reason: A device attached to the system is not functioning.
    I 21:10:52 -> Drive 2 - Info: ASUS BW-16D1H-U A201 (F:) (USB)
    I 21:10:52 Found 1 DVD±RW/RAM and 1 BD-RE XL!
    I 21:13:25 Operation Started!
    I 21:13:25 Building Image Tree...
    I 21:13:26 Calculating Totals...
    I 21:13:26 Preparing Image...
    I 21:13:26 Contents: 86 Files, 18 Folders
    I 21:13:26 Content Type: BD Video
    I 21:13:26 Data Type: MODE1/2048
    I 21:13:26 File System(s): UDF (2.50)
    I 21:13:26 Volume Label: [Not Configured]
    I 21:13:26 Size: 48,877,311,079 bytes
    I 21:13:26 Sectors: 23,865,934
    I 21:13:26 Image Size: 48,878,714,880 bytes
    I 21:13:26 Image Sectors: 23,866,560
    I 21:13:26 Operation Successfully Completed! - Duration: 00:00:00
    I 21:14:00 Operation Started!
    I 21:14:00 Building Image Tree...
    I 21:14:12 Calculating Totals...
    I 21:14:12 Preparing Image...
    I 21:14:12 Contents: 86 Files, 18 Folders
    I 21:14:12 Content Type: BD Video
    I 21:14:12 Data Type: MODE1/2048
    I 21:14:12 File System(s): UDF (2.50)
    I 21:14:12 Volume Label: Highway (2014) Untouched {Reliance} BD50 AVC MultiAudio ESub CA (DUS)
    I 21:14:12 Size: 48,877,311,079 bytes
    I 21:14:12 Sectors: 23,865,934
    I 21:14:12 Image Size: 48,878,714,880 bytes
    I 21:14:12 Image Sectors: 23,866,560
    I 21:14:15 Operation Successfully Completed! - Duration: 00:00:14
    I 21:14:15 Operation Started!
    I 21:14:15 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 21:14:15 Source File Sectors: 23,866,560 (MODE1/2048)
    I 21:14:15 Source File Size: 48,878,714,880 bytes
    I 21:14:15 Source File Volume Identifier: Highway (2014) Untouched {Reliance} BD50 AVC MultiAudio ESub CA (DUS)
    I 21:14:15 Source File Volume Set Identifier: 4927A9C0016C2C0E
    I 21:14:15 Source File Application Identifier: ImgBurn v2.5.8.0
    I 21:14:15 Source File Implementation Identifier: ImgBurn
    I 21:14:15 Source File File System(s): UDF (2.50)
    I 21:14:15 Destination Device: [0:0:0] ASUS BW-16D1H-U A201 (F:) (USB)
    I 21:14:15 Destination Media Type: BD-R (Disc ID: VERBAT-IMf-000)
    I 21:14:15 Destination Media Supported Write Speeds: 2x, 4x, 6x, 8x
    I 21:14:15 Destination Media Sectors: 24,438,784
    I 21:14:15 Write Mode: BD
    I 21:14:15 Write Type: Incremental
    I 21:14:15 Write Speed: 2x
    I 21:14:15 Hardware Defect Management Active: No
    I 21:14:15 BD-R Verify Not Required: Yes
    I 21:14:15 Link Size: Auto
    I 21:14:15 Lock Volume: Yes
    I 21:14:15 Test Mode: No
    I 21:14:15 OPC: No
    I 21:14:15 BURN-Proof: Enabled
    I 21:14:18 Write Speed Successfully Set! - Effective: 8,992 KB/s (2x)
    I 21:14:54 Filling Buffer... (80 MiB)
    I 21:14:56 Writing LeadIn...
    I 21:14:58 Writing Session 1 of 1... (1 Track, LBA: 0 - 23866559)
    I 21:14:58 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 23866559)
    I 21:14:58 Writing Layer 0... (LBA: 0 - 12219391)
    I 21:58:08 Writing Layer 1... (LBA: 12219392 - 23866559)
    W 22:04:37 Failed to Write Sectors 15599904 - 15599935 - Reason: Invalid Field in CDB
    W 22:04:37 Retrying (1 of 20)...
    W 22:04:37 Retry Failed - Reason: Invalid Field in CDB
    W 22:04:37 Retrying (2 of 20)...
    W 22:04:37 Retrying (3 of 20)...
    W 22:04:37 Retrying (4 of 20)...
    W 22:04:37 Retrying (5 of 20)...
    W 22:04:37 Retrying (6 of 20)...
    W 22:04:37 Retrying (7 of 20)...
    W 22:04:37 Retrying (8 of 20)...
    W 22:04:37 Retrying (9 of 20)...
    W 22:04:37 Retrying (10 of 20)...
    W 22:04:37 Retrying (11 of 20)...
    W 22:04:37 Retrying (12 of 20)...
    W 22:04:37 Retrying (13 of 20)...
    W 22:04:37 Retrying (14 of 20)...
    W 22:04:37 Retrying (15 of 20)...
    W 22:04:37 Retrying (16 of 20)...
    W 22:04:37 Retrying (17 of 20)...
    W 22:04:37 Retrying (18 of 20)...
    W 22:04:37 Retrying (19 of 20)...
    W 22:04:37 Retrying (20 of 20)...
    E 22:05:10 Failed to Write Sectors 15599904 - 15599935 - Reason: Invalid Field in CDB
    I 22:05:11 Synchronising Cache...
    W 22:05:11 Synchronise Cache Failed! - Reason: Invalid Field in CDB
    E 22:05:16 Synchronise Cache Failed! - Reason: Invalid Field in CDB
    I 22:05:24 Closing Track...
    W 22:05:24 Close Track Failed! - Reason: Invalid Field in CDB
    E 22:05:26 Close Track Failed! - Reason: Invalid Field in CDB
    I 22:05:26 Finalising Disc...
    W 22:05:26 Finalise Disc Failed! - Reason: Invalid Field in CDB
    E 22:05:27 Finalise Disc Failed! - Reason: Invalid Field in CDB
    E 22:05:27 Failed to Write Image!
    I 22:05:27 Exporting Graph Data...
    I 22:05:27 Graph Data File: C:\Users\navarose\AppData\Roaming\ImgBurn\Graph Data Files\ASUS_BW-16D1H-U_A201_WEDNESDAY-SEPTEMBER-07-2016_9-14_PM_VERBAT-IMf-000_2x.ibg
    I 22:05:27 Export Successfully Completed!
    E 22:05:27 Operation Failed! - Duration: 00:51:12
    I 22:05:27 Average Write Rate: 10,358 KiB/s (2.4x) - Maximum Write Rate: 17,928 KiB/s (4.1x)
    I 22:05:49 Close Request Acknowledged
    I 22:05:50 Closing Down...
    I 22:05:50 Shutting down SPTI...
    I 22:05:50 ImgBurn closed!
    ;   Wednesday, 07 September 2016, 18:39:35
    I 18:39:12 ImgBurn Version 2.5.8.0 started!
    I 18:39:12 Microsoft Windows 7 Home Basic x64 Edition (6.1, Build 7601 : Service Pack 1)
    I 18:39:12 Total Physical Memory: 4,098,104 KiB  -  Available: 1,333,908 KiB
    I 18:39:12 Initialising SPTI...
    I 18:39:12 Searching for SCSI / ATAPI devices...
    I 18:39:13 -> Drive 1 - Info: TSSTcorp DVD+-RW SN-208BB D300 (E:) (SATA)
    I 18:39:13 -> Drive 2 - Info: ASUS BW-16D1H-U A201 (F:) (USB 3.0)
    I 18:39:13 Found 1 DVD±RW/RAM and 1 BD-RE XL!
    I 18:39:35 Close Request Acknowledged
    I 18:39:35 Closing Down...
    I 18:39:35 Shutting down SPTI...
    I 18:39:35 ImgBurn closed!
    ;   Friday, 26 August 2016, 15:48:38
    I 13:47:04 ImgBurn Version 2.5.8.0 started!
    I 13:47:04 Microsoft Windows 7 Home Basic x64 Edition (6.1, Build 7601 : Service Pack 1)
    I 13:47:04 Total Physical Memory: 4,098,104 KiB  -  Available: 551,096 KiB
    I 13:47:04 Initialising SPTI...
    I 13:47:04 Searching for SCSI / ATAPI devices...
    I 13:47:11 -> Drive 1 - Info: TSSTcorp DVD+-RW SN-208BB D300 (E:) (SATA)
    I 13:47:11 -> Drive 2 - Info: TSSTcorp BDDVDW SE-506CB TS01 (F:) (USB 2.0)
    I 13:47:11 Found 1 DVD±RW/RAM and 1 BD-RE XL!
    I 13:54:02 Operation Started!
    I 13:54:02 Building Image Tree...
    I 13:54:19 Corrected file system selection for Blu-ray Video disc.
    I 13:54:19 Corrected UDF revision selection for Blu-ray Video disc.
    I 13:54:19 Calculating Totals...
    I 13:54:19 Preparing Image...
    I 13:54:19 Contents: 40 Files, 17 Folders
    I 13:54:19 Content Type: BD Video
    I 13:54:19 Data Type: MODE1/2048
    I 13:54:19 File System(s): UDF (2.50)
    I 13:54:19 Volume Label: [Not Configured]
    I 13:54:19 Size: 42,967,779,122 bytes
    I 13:54:19 Sectors: 20,980,388
    I 13:54:19 Image Size: 42,969,006,080 bytes
    I 13:54:19 Image Sectors: 20,980,960
    I 13:54:19 Operation Successfully Completed! - Duration: 00:00:16
    I 13:56:04 Operation Started!
    I 13:56:04 Building Image Tree...
    I 13:56:04 Calculating Totals...
    I 13:56:04 Preparing Image...
    I 13:56:04 Contents: 40 Files, 17 Folders
    I 13:56:04 Content Type: BD Video
    I 13:56:04 Data Type: MODE1/2048
    I 13:56:04 File System(s): UDF (2.50)
    I 13:56:04 Volume Label: PREMAM
    I 13:56:04 Size: 42,967,779,122 bytes
    I 13:56:04 Sectors: 20,980,388
    I 13:56:04 Image Size: 42,969,006,080 bytes
    I 13:56:04 Image Sectors: 20,980,960
    I 13:56:17 Operation Successfully Completed! - Duration: 00:00:13
    I 13:56:17 Operation Started!
    I 13:56:17 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 13:56:17 Source File Sectors: 20,980,960 (MODE1/2048)
    I 13:56:17 Source File Size: 42,969,006,080 bytes
    I 13:56:17 Source File Volume Identifier: PREMAM
    I 13:56:17 Source File Volume Set Identifier: 491A6F0201402444
    I 13:56:17 Source File Application Identifier: ImgBurn v2.5.8.0
    I 13:56:17 Source File Implementation Identifier: ImgBurn
    I 13:56:17 Source File File System(s): UDF (2.50)
    I 13:56:17 Destination Device: [0:0:0] TSSTcorp BDDVDW SE-506CB TS01 (F:) (USB)
    I 13:56:17 Destination Media Type: BD-R (Disc ID: MEI-T02-001)
    I 13:56:17 Destination Media Supported Write Speeds: 2x, 4x
    I 13:56:18 Destination Media Sectors: 24,438,784
    I 13:56:18 Write Mode: BD
    I 13:56:18 Write Type: DAO
    I 13:56:18 Write Speed: 4x
    I 13:56:18 Hardware Defect Management Active: No
    I 13:56:18 BD-R Verify Not Required: Yes
    I 13:56:18 Link Size: Auto
    I 13:56:18 Lock Volume: Yes
    I 13:56:18 Test Mode: No
    I 13:56:18 OPC: No
    I 13:56:18 BURN-Proof: Enabled
    I 13:56:18 Write Speed Successfully Set! - Effective: 17,984 KB/s (4x)
    I 13:57:25 Filling Buffer... (80 MiB)
    I 13:57:28 Writing LeadIn...
    I 13:57:29 Writing Session 1 of 1... (1 Track, LBA: 0 - 20980959)
    I 13:57:29 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 20980959)
    I 13:57:29 Writing Layer 0... (LBA: 0 - 12219391)
    W 14:24:03 Failed to Write Sectors 12044064 - 12044095 - Reason: Write Error
    W 14:24:03 Retrying (1 of 20)...
    W 14:24:09 Retry Failed - Reason: Invalid Address For Write
    W 14:24:09 Retrying (2 of 20)...
    W 14:24:09 Retrying (3 of 20)...
    W 14:24:09 Retrying (4 of 20)...
    W 14:24:09 Retrying (5 of 20)...
    W 14:24:09 Retrying (6 of 20)...
    W 14:24:09 Retrying (7 of 20)...
    W 14:24:09 Retrying (8 of 20)...
    W 14:24:09 Retrying (9 of 20)...
    W 14:24:09 Retrying (10 of 20)...
    W 14:24:09 Retrying (11 of 20)...
    W 14:24:09 Retrying (12 of 20)...
    W 14:24:10 Retry Failed - Reason: Invalid Address For Write
    W 14:24:10 Retrying (13 of 20)...
    W 14:24:10 Retrying (14 of 20)...
    W 14:24:10 Retrying (15 of 20)...
    W 14:24:10 Retrying (16 of 20)...
    W 14:24:10 Retrying (17 of 20)...
    W 14:24:10 Retrying (18 of 20)...
    W 14:24:10 Retrying (19 of 20)...
    W 14:24:10 Retrying (20 of 20)...
    W 14:26:32 Retrying (21)...
    W 14:26:35 Retry Failed - Reason: Invalid Address For Write
    W 14:26:37 Retrying (22)...
    W 14:26:37 Retry Failed - Reason: Invalid Address For Write
    W 14:26:37 Retrying (23)...
    W 14:26:38 Retrying (24)...
    W 14:26:38 Retry Failed - Reason: Invalid Address For Write
    W 14:26:39 Retrying (25)...
    W 14:26:39 Retry Failed - Reason: Invalid Address For Write
    W 14:26:39 Retrying (26)...
    W 14:26:40 Retrying (27)...
    W 14:26:40 Retry Failed - Reason: Invalid Address For Write
    E 14:27:30 Failed to Write Sectors 12044064 - 12044095 - Reason: Write Error
    E 14:27:30 Next Writable Address: 0
    I 14:27:31 Synchronising Cache...
    W 14:27:38 User opted to skip the 'Close Track/Session/Disc' functions.
    E 14:27:38 Failed to Write Image!
    I 14:27:38 Exporting Graph Data...
    I 14:27:39 Graph Data File: C:\Users\navarose\AppData\Roaming\ImgBurn\Graph Data Files\TSSTcorp_BDDVDW_SE-506CB_TS01_FRIDAY-AUGUST-26-2016_1-56_PM_MEI-T02-001_4x.ibg
    I 14:27:39 Export Successfully Completed!
    E 14:27:39 Operation Failed! - Duration: 00:31:20
    I 14:27:39 Average Write Rate: 13,374 KiB/s (3.0x) - Maximum Write Rate: 18,132 KiB/s (4.1x)
    I 14:44:18 Operation Started!
    I 14:44:18 Building Image Tree...
    I 14:44:18 Calculating Totals...
    I 14:44:18 Preparing Image...
    I 14:44:18 Contents: 40 Files, 17 Folders
    I 14:44:18 Content Type: BD Video
    I 14:44:18 Data Type: MODE1/2048
    I 14:44:18 File System(s): UDF (2.50)
    I 14:44:18 Volume Label: PREMAM
    I 14:44:18 Size: 42,967,779,122 bytes
    I 14:44:18 Sectors: 20,980,388
    I 14:44:18 Image Size: 42,969,006,080 bytes
    I 14:44:18 Image Sectors: 20,980,960
    I 14:44:19 Operation Successfully Completed! - Duration: 00:00:01
    I 14:44:19 Operation Started!
    I 14:44:19 Source File: -==/\/[BUILD IMAGE]\/\==-
    I 14:44:19 Source File Sectors: 20,980,960 (MODE1/2048)
    I 14:44:19 Source File Size: 42,969,006,080 bytes
    I 14:44:19 Source File Volume Identifier: PREMAM
    I 14:44:19 Source File Volume Set Identifier: 491A758901402444
    I 14:44:19 Source File Application Identifier: ImgBurn v2.5.8.0
    I 14:44:19 Source File Implementation Identifier: ImgBurn
    I 14:44:19 Source File File System(s): UDF (2.50)
    I 14:44:19 Destination Device: [0:0:0] TSSTcorp BDDVDW SE-506CB TS01 (F:) (USB)
    I 14:44:19 Destination Media Type: BD-R (Disc ID: MEI-T02-001)
    I 14:44:19 Destination Media Supported Write Speeds: 2x, 4x
    I 14:44:19 Destination Media Sectors: 24,438,784
    I 14:44:19 Write Mode: BD
    I 14:44:19 Write Type: Incremental
    I 14:44:19 Write Speed: 2x
    I 14:44:19 Hardware Defect Management Active: No
    I 14:44:19 BD-R Verify Not Required: Yes
    I 14:44:19 Link Size: Auto
    I 14:44:19 Lock Volume: Yes
    I 14:44:19 Test Mode: No
    I 14:44:19 OPC: No
    I 14:44:19 BURN-Proof: Enabled
    I 14:44:19 Write Speed Successfully Set! - Effective: 8,992 KB/s (2x)
    I 14:45:37 Filling Buffer... (80 MiB)
    I 14:46:31 Writing LeadIn...
    I 14:46:40 Writing Session 1 of 1... (1 Track, LBA: 0 - 20980959)
    I 14:46:40 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 20980959)
    I 14:46:40 Writing Layer 0... (LBA: 0 - 12219391)
    W 14:47:02 Waiting for buffers to recover... (LBA: 65344)
    W 14:47:24 Waiting for hard disk activity to reach threshold level...
    I 14:47:27 Writing Sectors...
    W 15:29:07 Failed to Write Sectors 12015904 - 12015935 - Reason: Write Error
    W 15:29:07 Retrying (1 of 20)...
    W 15:29:07 Retry Failed - Reason: Invalid Address For Write
    W 15:29:07 Retrying (2 of 20)...
    W 15:29:07 Retrying (3 of 20)...
    W 15:29:08 Retry Failed - Reason: Invalid Address For Write
    W 15:29:08 Retrying (4 of 20)...
    W 15:29:08 Retrying (5 of 20)...
    W 15:29:08 Retrying (6 of 20)...
    W 15:29:08 Retrying (7 of 20)...
    W 15:29:08 Retrying (8 of 20)...
    W 15:29:08 Retrying (9 of 20)...
    W 15:29:08 Retrying (10 of 20)...
    W 15:29:08 Retrying (11 of 20)...
    W 15:29:08 Retrying (12 of 20)...
    W 15:29:08 Retrying (13 of 20)...
    W 15:29:08 Retrying (14 of 20)...
    W 15:29:08 Retrying (15 of 20)...
    W 15:29:08 Retrying (16 of 20)...
    W 15:29:08 Retrying (17 of 20)...
    W 15:29:08 Retrying (18 of 20)...
    W 15:29:08 Retrying (19 of 20)...
    W 15:29:08 Retrying (20 of 20)...
    W 15:48:21 Retrying (21)...
    W 15:48:24 Retry Failed - Reason: Invalid Address For Write
    W 15:48:25 Retrying (22)...
    W 15:48:25 Retry Failed - Reason: Invalid Address For Write
    E 15:48:26 Failed to Write Sectors 12015904 - 12015935 - Reason: Write Error
    E 15:48:26 Next Writable Address: 65344
    I 15:48:26 Synchronising Cache...
    W 15:48:30 User opted to skip the 'Close Track/Session/Disc' functions.
    E 15:48:30 Failed to Write Image!
    I 15:48:30 Exporting Graph Data...
    I 15:48:30 Graph Data File: C:\Users\navarose\AppData\Roaming\ImgBurn\Graph Data Files\TSSTcorp_BDDVDW_SE-506CB_TS01_FRIDAY-AUGUST-26-2016_2-44_PM_MEI-T02-001_2x.ibg
    I 15:48:30 Export Successfully Completed!
    E 15:48:30 Operation Failed! - Duration: 01:04:10
    I 15:48:30 Average Write Rate: 6,484 KiB/s (1.5x) - Maximum Write Rate: 9,739 KiB/s (2.2x)
    I 15:48:37 Close Request Acknowledged
    I 15:48:37 Closing Down...
    I 15:48:37 Shutting down SPTI...
    I 15:48:37 ImgBurn closed!
    ;   Friday, 26 August 2016, 12:04:51
    I 12:04:23 ImgBurn Version 2.5.8.0 started!
    I 12:04:23 Microsoft Windows 7 Home Basic x64 Edition (6.1, Build 7601 : Service Pack 1)
    I 12:04:23 Total Physical Memory: 4,098,104 KiB  -  Available: 830,760 KiB
    I 12:04:23 Initialising SPTI...
    I 12:04:23 Searching for SCSI / ATAPI devices...
    I 12:04:30 -> Drive 1 - Info: TSSTcorp DVD+-RW SN-208BB D300 (E:) (SATA)
    I 12:04:31 -> Drive 2 - Info: TSSTcorp BDDVDW SE-506CB TS01 (F:) (USB 2.0)
    I 12:04:31 Found 1 DVD±RW/RAM and 1 BD-RE XL!
    I 12:04:50 Close Request Acknowledged
    I 12:04:50 Closing Down...
    I 12:04:51 Shutting down SPTI...
    I 12:04:51 ImgBurn closed!
    Feb 2006
    Start imgburn and click tools - settings - write - check "perform OPC before write"
    Click ok, retry burning again.
  3. Originally Posted by october262 View Post
    Let me do that. To addd on I converted the bdmv and certificate to iso and tried burning it also failed
    ;   Thursday, 08 September 2016, 07:21:52
    I 00:23:04 ImgBurn Version 2.5.8.0 started!
    I 00:23:04 Microsoft Windows 7 Home Basic x64 Edition (6.1, Build 7601 : Service Pack 1)
    I 00:23:04 Total Physical Memory: 4,098,104 KiB  -  Available: 1,268,672 KiB
    I 00:23:04 Initialising SPTI...
    I 00:23:04 Searching for SCSI / ATAPI devices...
    I 00:23:06 -> Drive 1 - Info: TSSTcorp DVD+-RW SN-208BB D300 (E:) (SATA)
    E 00:23:06 DeviceIoControl(IOCTL_USB_GET_NODE_CONNECTION_INFORMATION_EX) Failed!
    E 00:23:06 Reason: A device attached to the system is not functioning.
    I 00:23:06 -> Drive 2 - Info: ASUS BW-16D1H-U A201 (F:) (USB)
    I 00:23:06 Found 1 DVD±RW/RAM and 1 BD-RE XL!
    I 00:26:49 Operation Started!
    I 00:26:49 Source File: C:\SULTAN.ISO
    I 00:26:49 Source File Sectors: 23,978,464 (MODE1/2048)
    I 00:26:49 Source File Size: 49,107,894,272 bytes
    I 00:26:49 Source File Volume Identifier: SULTAN
    I 00:26:49 Source File Volume Set Identifier: 4927B978016DE140
    I 00:26:49 Source File Application Identifier: ImgBurn v2.5.8.0
    I 00:26:49 Source File Implementation Identifier: ImgBurn
    I 00:26:49 Source File File System(s): UDF (2.50)
    I 00:26:49 Destination Device: [0:0:0] ASUS BW-16D1H-U A201 (F:) (USB)
    I 00:26:49 Destination Media Type: BD-R (Disc ID: VERBAT-IMf-000)
    I 00:26:49 Destination Media Supported Write Speeds: 2x, 4x, 6x, 8x
    I 00:26:49 Destination Media Sectors: 24,438,784
    I 00:26:49 Write Mode: BD
    I 00:26:49 Write Type: Incremental
    I 00:26:49 Write Speed: 2x
    I 00:26:49 Hardware Defect Management Active: No
    I 00:26:49 BD-R Verify Not Required: Yes
    I 00:26:49 Link Size: Auto
    I 00:26:49 Lock Volume: Yes
    I 00:26:49 Test Mode: No
    I 00:26:49 OPC: No
    I 00:26:49 BURN-Proof: Enabled
    I 00:26:51 Write Speed Successfully Set! - Effective: 8,992 KB/s (2x)
    I 00:27:27 Filling Buffer... (73 MiB)
    I 00:27:28 Writing LeadIn...
    I 00:27:30 Writing Session 1 of 1... (1 Track, LBA: 0 - 23978463)
    I 00:27:30 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 23978463)
    I 00:27:30 Writing Layer 0... (LBA: 0 - 12219391)
    I 01:12:28 Writing Layer 1... (LBA: 12219392 - 23978463)
    W 01:22:50 Failed to Write Sectors 15012064 - 15012095 - Reason: Invalid Field in CDB
    W 01:22:50 Retrying (1 of 20)...
    W 01:22:50 Retry Failed - Reason: Invalid Field in CDB
    W 01:22:50 Retrying (2 of 20)...
    W 01:22:50 Retrying (3 of 20)...
    W 01:22:50 Retrying (4 of 20)...
    W 01:22:50 Retrying (5 of 20)...
    W 01:22:50 Retrying (6 of 20)...
    W 01:22:50 Retrying (7 of 20)...
    W 01:22:50 Retrying (8 of 20)...
    W 01:22:50 Retrying (9 of 20)...
    W 01:22:50 Retrying (10 of 20)...
    W 01:22:50 Retrying (11 of 20)...
    W 01:22:50 Retrying (12 of 20)...
    W 01:22:50 Retrying (13 of 20)...
    W 01:22:50 Retrying (14 of 20)...
    W 01:22:50 Retrying (15 of 20)...
    W 01:22:50 Retrying (16 of 20)...
    W 01:22:50 Retrying (17 of 20)...
    W 01:22:50 Retrying (18 of 20)...
    W 01:22:50 Retrying (19 of 20)...
    W 01:22:50 Retrying (20 of 20)...
    W 07:21:28 Retrying (21)...
    W 07:21:28 Retry Failed - Reason: Invalid Field in CDB
    W 07:21:29 Retrying (22)...
    W 07:21:29 Retry Failed - Reason: Invalid Field in CDB
    W 07:21:30 Retrying (23)...
    W 07:21:30 Retry Failed - Reason: Invalid Field in CDB
    W 07:21:30 Retrying (24)...
    E 07:21:31 Failed to Write Sectors 15012064 - 15012095 - Reason: Invalid Field in CDB
    I 07:21:31 Synchronising Cache...
    W 07:21:31 Synchronise Cache Failed! - Reason: Invalid Field in CDB
    E 07:21:36 Synchronise Cache Failed! - Reason: Invalid Field in CDB
    I 07:21:38 Closing Track...
    W 07:21:38 Close Track Failed! - Reason: Invalid Field in CDB
    E 07:21:41 Close Track Failed! - Reason: Invalid Field in CDB
    I 07:21:41 Finalising Disc...
    W 07:21:41 Finalise Disc Failed! - Reason: Invalid Field in CDB
    E 07:21:45 Finalise Disc Failed! - Reason: Invalid Field in CDB
    E 07:21:45 Failed to Write Image!
    I 07:21:46 Exporting Graph Data...
    I 07:21:46 Graph Data File: C:\Users\navarose\AppData\Roaming\ImgBurn\Graph Data Files\ASUS_BW-16D1H-U_A201_THURSDAY-SEPTEMBER-08-2016_12-26_AM_VERBAT-IMf-000_2x.ibg
    I 07:21:46 Export Successfully Completed!
    E 07:21:46 Operation Failed! - Duration: 06:54:56
    I 07:21:46 Average Write Rate: 1,208 KiB/s (0.3x) - Maximum Write Rate: 14,538 KiB/s (3.3x)
    I 07:21:51 Close Request Acknowledged
    I 07:21:51 Closing Down...
    I 07:21:52 Shutting down SPTI...
    I 07:21:52 ImgBurn closed!
  4. Originally Posted by october262 View Post
    That also failed mate
    Feb 2006
    try updating your computer bluray drive firmware.
  6. Originally Posted by october262 View Post
    Im giving up mate. Such a sense of frustration.So much money, time wasted.
    IS there a way to play the downloaded bdmv files from a hard disk just like the disk itself(with menu etc)
    Feb 2006
    Get something like a media player and put your movies on it.
    Plus you don't have to worry about cinavia. Media players are immune to cinavia.
  8. Originally Posted by october262 View Post
    Basically my whole purpose is to play the content like the bd disk, with menus navigation etc. I dont mind buying a 4TB hard disk and putting all the untouched BD content to that.
