  1. So I tried getting this show through Channel 5 using FFMPEG and making an output file.
    I got an M3u8 link using IDM but I when I tried using FFMPEG I got error in 1st segment or something like that.
    This is the link IDM gave me.
    http://akahls.channel5.com/C5214880005/C5214880005A/20160904014436/video/1500/C5214880005A_1500.m3u8
    I tried another one
    http://akahls.channel5.com/C5214880005/C5214880005A/20160904014436/video/800/C52148800...00.m3u8?faxs=1
    But I had no luck whatsoever.
    Am I doing it wrong?
    Any help would be appreciated
    You might need a UK VPN TO access it
    https://www.my5.tv/football-on-5-goal-rush/season-201617/episode-5
    Thank you once again !
  2. Did you ever find a solution to this ?, the .ts files are encrypted and you need the key file to decrypt them, assuming the keyfile itself is not encrypted, somewhere down the line it is going to the adobe primetime server with the .drm file and in response is getting a very long key, maybe the decryption method might be in the .swf file or something, not too sure at this point, been scratching my head at this one for a while.
