Results 1 to 13 of 13
  1. Hello, dear all.
    I have the old version from this program. 8.x.x.x. And use that giveaway keys too.
    ---> https://www.videohelp.com/software/DVDFab-Passkey
    But now, version 9.0.0.1 or newer 9.x.x.x versions probably will need new keys also?
    Do you have to "downgrade" to older version the keep the program working without 30 days trial mode or something?
    Do you know if Fengtao will give any more giveway licenses someday again?
    Thanks.
    Best regards.
    devil (johner)
  2. Anonymous
    Guest
    Hi
    Read this forum post: forum.dvdfab.cn/showthread.php?t=29784
    You can downgrade, just uninstall version 9, install version 8 and use the give away key.
    Don't upgrade again, and in settings turn of automatic check for updates..
    Version 8 continue to work for life with the give away key but no new encryption keys are provided as of release of version 9
  3. so, there won't be a free Lite version of 9 and on?
    edoy: ok, never mind. the lite is free.
    just another question:
    i'm not interested in backing up blurays, just playing them.
    So, from what i understand the lite version is enough for that?
  4. Hi, It is enough if you just play the old blurays with passkey 8. If you want to play disc with new protection, Passkey 9 is needed.
  5. Originally Posted by DVDFab Staff View Post
    I see.
    So, I understand that if I update every time with the latest version of Passkey lite, I won't have a problem with newer blurays too.
    Right now I have 9.1.
  6. Hello.
    I have a problem.
    I can't start the lite version? why is that?
    Isn't the lite version supposed to be free?
    Nov 2003
    West Texas
    Can you highlight the line that says Lite (Free), then click on Start DVDFab Passkey?
  8. Originally Posted by Kerry56 View Post
    No, it doesn't help I'm afraid..
  9. Ok, I think it works now.
    I needed to activate (register in the DVDfab site and put email/password when you hit activation).
    You needn't have purchased any product.
    Strange, because it didn't require it up until now..
    edit: the disappointing fact is that they don't update protections with the lite version.
    Just tried a Bluray released in November of 2016 and it can't play it.
    I thought that the lite version can only play Blurays (any bluray updated regularly) but it just can't back up them.
    Nov 2003
    West Texas
    Thanks for the clarification on how to get it to work.
    No, that's not how it works. You have to have effective, up to date decryption whether you are copying or playing the movie in an unauthorized program.
  11. Ok. I'm still confused here after all these months.
    What does the lite version actually do?
    If you can't watch or decrypt blurays with it, what does it do?
    Feb 2006
    see here - https://www.dvdfab.cn/passkey-lite.htm
  13. Originally Posted by october262 View Post
    Yes, i saw that.
    it says:
    For Blu-ray, it can remove AACS lower than V36, RC, BD-Live, and UOPs. It also gives you the power to change the region settings of Blu-ray players Power DVD and TotalMedia Theatre.
    well, it doesn't work even for that: changing region settings.
    And about those protections:
    Where can I see, what protection does a disc have?
