Hi VideoHelp Forum Team,
I would like to implement a custom RTMP transcoder to HLS format in Java and I found the modification of the video resolution a bit challenging in Java. My plan is to minimize the amount of 3rd party frameworks/tools integrated with my component.
What would be the best library (C/C++/Java) that could be used to decrease a resolution/bitrate of the RTMP stream to match adaptive streaming? I mean modification of the bitrate/resolution of H.264 videos/stream. Are there any alternatives to ffmpeg/libav? Would you recommend any commercial libraries?
Thanks!
Kind regards,
Jan Kowalski
Results 1 to 1 of 1
Resolution, Bitrate and Quality
By JonNorway in forum Video ConversionReplies: 12Last Post: 19th May 2016, 14:24 -
4K Videos on PotPlayer: How Decrease Display Resolution?
By KenithOlson in forum Software PlayingReplies: 2Last Post: 20th Aug 2014, 11:37 -
Need help selecting tool for batch/folder conversion of large library
By snootch in forum Video ConversionReplies: 4Last Post: 27th Feb 2013, 00:50 -
Bitrate and resolution
By carlmart in forum Video ConversionReplies: 6Last Post: 22nd Jan 2013, 13:52 -
Can I go from M2ts to M2ts & just decrease the resolution
By jbitakis in forum Video ConversionReplies: 44Last Post: 9th Dec 2012, 08:59
