There are times when I capture streaming video files and you get the odd one that you notice problems when playing it back on the Blu Ray player. The problems are that once you go beyond a certain length of time into the video you can't pause it or you can't fast forward without things getting disjointed. When I check out that file with MediaInfo I find that in the specs for the video part of the file it will have the duration of the video lets say 45 minutes and there will be a line directly underneath saying source duration lets say 17 minutes. So up to that 17 minute mark on the Blu Ray player it will pay just fine, you can fast forward and pause with no problems up that point. Somehow I ran across the solution which is to drop the file into the video to video converter and select "direct stream copy" and let the file be converted. The only thing that changes with the file is that source duration line is gone in the resulting file when you check it in MediaInfo. Then you play that file on the Blu Ray player and no more problems. I am curious though what causes such a problem in the first place.
cause: broken headers in the container structure. Remuxing causes the headers of the container to be recreated and thus fixed the problem.
MPEG-2 aspect ratio problem when burn to DVD (Will pay $50 for solution)
By prodos in forum Newbie / General discussionsReplies: 25Last Post: 3rd Jan 2015, 00:53 -
Looking for a solution: CS6 Premier export problem
By processfailed in forum Newbie / General discussionsReplies: 4Last Post: 18th Nov 2013, 01:30 -
Any solution for Handycam / Windows 7 driver problem?
By tedmarx38 in forum Capturing and VCRReplies: 4Last Post: 11th Nov 2012, 12:39 -
WinAvi no sound / no audio problem - solution
By bukimi in forum User guidesReplies: 2Last Post: 9th Jul 2012, 15:50 -
Audio/Mic problem during filming, need a solution..
By sdsumike619 in forum AudioReplies: 16Last Post: 31st Jan 2012, 19:17
