Hello everyone, this is my first post on this forum after a lot reading of your discussions. But I can't find a solution for my problem. I want to convert two ripped BR mkv movies (who are in resolution 1920x800 and DTS-6 sound) for watching them as usual BDR discs in my PS3, and I'm using a lot of different apps for that (AVCHDconvert, BDRebuilder, multiAVCHD, tsmuxer) but with constant same result - my PS3 plays BD-R disc, but only sound - no video! When trying same disc on my PC everything is ok, video and audio are in perfect sync. What I'm doing wrong?
PS: In folder BDMV/STREAM I get two m2ts files, one is the main movie in genuine resolution, but the other is 1920x1080, very small (about few kbs), is that ok?
1920 x 800 isn't compliant to Blu-ray specifications, but the output from BDRebuilder should be 1920 x 1080 if you haven't strayed from the default settings. And no, it shouldn't be small. This sounds like the main problem.
Take a look at the m2ts files that BD Rebuilder makes using MediaInfo. Use either the Tree or Text views, then paste the results here in your thread.
If that looks ok, then you might just have a picky PS3, that doesn't like burned discs. Are you using ImgBurn to do the actual burn to the disc? And what type of media are you using? -
First m2ts file is big enough, and it says it's the main video. The other is in FHD resolution (1080p) and is very small. I get one big and those small file everytime, whatever software...
For experiment, I have tried regular mkv 1080p movie (1920x1080) and I get only one (big) m2ts file. Everything went ok, PS3 is showing video. Bluray in PS is ok. -
There is no problem to play on PS3 various resolutions (frequently encoding own 4GiB movie files to place on PS3 HDD and play on home TV).
Streaming bluray from ps3 media server
By Psco2007 in forum Video Streaming DownloadingReplies: 5Last Post: 14th Feb 2014, 14:39 -
Through The Wormhole S01 2 Disc Bluray - Disc 2 shown as empty??
By KDC in forum Blu-ray RippingReplies: 3Last Post: 8th Sep 2012, 06:40 -
BluRay disc burned with ImgBurn plays on some players, not others inc. ps3
By tikigod19 in forum Authoring (Blu-ray)Replies: 12Last Post: 14th Aug 2012, 04:42 -
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 14:39
