    Mar 2011
    Paris, France
    Hello
    I'm using the latest and greatest (ffmpeg N-79690-g78baa45).
    For some reason, the following doesn't work as expected: Instead of slicing the video after 5mn, it keeps going for 10:
    ffmpeg -ss 00:15:17 -i input.mp4 -to 00:20:17 -c copy -threads 2 -f mp4 output.mp4
    Same result:
    ffmpeg -ss 00:15:17 -i input.mp4 -to 00:20:17 -c:v libx264  -pix_fmt yuv420p -c:a copy -threads 2 -f mp4 output.mp4
    Any idea why? Did the ffmpeg team changed the meaning of the -to switch?
    Thank you.
  2. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Try:
    ffmpeg -ss 00:15:17 -i input.mp4 -t 00:05:00 -c copy -threads 2 -f mp4 output.mp4
    Aug 2010
    San Francisco, California
    I find that -to only works when -ss is entered as an output option.
    Mar 2011
    Paris, France
    Thanks. I don't want to use the -t option because the -to option lets me just type the end of the segment without having to compute how long it lasts.
    Why does it matter where I put the -ss and -to options?
    Here, they're put before the -i option:
    http://ffmpeg.io/howto
    Here, they're after:
    http://stackoverflow.com/questions/18444194/cutting-the-videos-based-on-start-and-end-...e-using-ffmpeg
    Edit: Here's the explanation:
    https://trac.ffmpeg.org/wiki/Seeking
    Nov 2015
    Lexington, MA
    "Thanks. I don't want to use the -t option because the -to option lets me just type the end of the segment without having to compute how long it lasts. Why does it matter where I put the -ss and -to options?"
    The -ss option can be either an input option or an output option. The -to option and -t option are only output options.
    If you use -ss and -to both on the output, then -to will work as you expect. The downside is that it will filter and encode all of the frames from the beginning of the file, then throw them out until the start time in -ss. Just a timewaster, but -to then works.
    If you use -ss before -i, then those frames are thrown away before processing, so the output never sees those frames. So as far as the -to can tell, the video is that much shorter and started at 0, instead of started at the -ss time.
    Want a clip from src video that starts at 2:30 and ends at 7:30...
    ffmpeg -i src.mpg <encode options> -ss 00:02:30 -to 00:07:30 dst.mpg
    ffmpeg -i src.mpg <encode options> -ss 00:02:30 -t 00:05:00 dst.mpg
    ffmpeg -i src.mpg <encode options> -ss 00:02:30 -t 300 dst.mpg
    ffmpeg -ss 00:02:30 -i src.mpg <encode options> -t 300 dst.mpg
    All but the last command process frames from the start of the file then drops them in the very last step before writing; the last command instead throws out those frames (very quickly) before processing and starts processing frames beginning with the -ss time.
    ffpmeg
  6. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    It doesn't matter if you use -t it - to. If you use -ss as an input it resets the timecode to 0 so -t and - to then means to a point from the ss point starting at 0. It is further complicated by the fact that if you use -c copy, ffmpeg will cut at a key frame but your first frame may not have a timecode of 0. This may play ok on some players but give problems if you try to merge it to another segment, even with the same parameters.
    There is a way to do it with -vframes that works but it is tricky also.
