Hello
I'm trying to learn LightWorks, but it appears to only accept files that use a constant frame rate, while my Sony camcorder uses CFR for audio while it uses VFR for video:
Do I have to re-encode the video stream before being able to edit the file in LW, or is there a faster, lossless work-around?Code:Format : MPEG-PS File size : 39.7 MiB Duration : 37s 920ms Overall bit rate mode : Variable Overall bit rate : 8 780 Kbps Video ID : 224 (0xE0) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=12 Format settings, picture structure : Frame Duration : 37s 920ms Bit rate mode : Variable Bit rate : 8 157 Kbps Maximum bit rate : 9 100 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.787 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header GOP, Open/Closed : Closed Stream size : 36.9 MiB (93%) Audio ID : 189 (0xBD)-128 (0x80) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Muxing mode : DVD-Video Duration : 37s 888ms Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Frame rate : 31.250 fps (1536 spf) Compression mode : Lossy Stream size : 2.02 MiB (5%)
Thank you.
It is CFR (constant frame rate) already
The bitrate is variable (VBR, variable bit rate) -
Your video is ordinary CFR (25fps) PAL mpeg2 video. Haven't used LW in a while, at the time it did not support DVD standard video natively. Does it now? Lightworks may also be having a problem with your 5.1 audio track.
The frame rate is constant, but the bit rate is variable, so audio and video are out of sync when playing a video after importing it in LW:
"You've got a variable frame rate, which means you'll lose sync. You need to convert your media to a constant frame rate codec before importing into Lightworks." https://www.lwks.com/index.php?option=com_kunena&func=view&catid=14&id=105599&Itemid=81
VFR to CFR
By SameSelf in forum Video ConversionReplies: 6Last Post: 7th Jun 2016, 20:46 -
RipBot264 and Handbrake producing VFR when CFR is selected
By duffbeer in forum Blu-ray RippingReplies: 9Last Post: 22nd Jan 2015, 09:50 -
Syncing VFR Video with Audio from CFR Video
By Chri5 in forum Newbie / General discussionsReplies: 11Last Post: 25th Jan 2014, 04:17 -
What mobile phones uses VFR (or CFR) for recorded video clips?
By Gew in forum Portable VideoReplies: 0Last Post: 27th Jan 2012, 12:49 -
VFR -> CFR in VirtualDub
By KeyMs92 in forum EditingReplies: 19Last Post: 7th Oct 2011, 19:41
