Hi there guys, been trying to sort this out for days now i cant figure it out.
From the beginning:
-I recorded a video on my phone, my phone died while i was still recording.
-This corrupted the mp4 file, which made in unplayable on any device. So i sent it to my PC and restored the file using Grau gmbH. And it worked. The file is now playable. Though all i can see is a black screen, sometimes grey (if i use VLC) with some green sections in it too. The sound is 100% there but there is no picture whatsoever.
Is there any way to get it working again? i would rather sacrafice the sound for the picture if thats the best result, as opposed to having sound but no Picture.
Thanks in advance
You could try graus video repair tool. Open a working mp4 from same phpne and the broken mp4 and try repair. The trial version will only repair half the movie but you will see if it gets any picture at all.
You could also try recover_mp4.
It's a command line/prompt software so it's not that easy, see
Code:Step 1: Use any good previous file with the same resolution and bitrate to generate the header files, for example >recover_mp4.exe good.mp4 --analyze It will create files 'video.hdr' and 'audio.hdr' in the current directory and print instructions (ffmpeg options, etc.). Step 2: Recover streams from the corrupted file, for example >recover_mp4.exe bad.mp4 recovered.h264 recovered.aac Note: Files 'video.hdr' and 'audio.hdr' must be exist. Probably you need to add a specific option (look at instructions from step 1). Step 3: Use any other utility (Yamb or ffmpeg for example) to recreate the MP4/MOV file from the streams (recovered.h264 and recovered.aac). >ffmpeg.exe -r 30 -i recovered.h264 -i recovered.aac -bsf:a aac_adtstoasc -c:v copy -c:a copy recovered.mp4
Accessing a corrupted Mp4
By Vidaket in forum Newbie / General discussionsReplies: 21Last Post: 26th Feb 2015, 16:37 -
Need help with corrupted .MP4
By Dyingsoul in forum Video ConversionReplies: 3Last Post: 1st Mar 2014, 08:47 -
MP4 corrupted
By RPGglitchy in forum RestorationReplies: 28Last Post: 20th Jun 2013, 18:43 -
corrupted .mp4 h.264
By bluesky1 in forum Software PlayingReplies: 8Last Post: 1st Jan 2012, 15:22 -
Help with Corrupted MP4 Video File
By jabetha in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2011, 08:04
