Just a guess. The screen may be edge lit and that plastic piece may have came loose or delaminated.
Usually if the backlight itself begins to die (florescent backlight), the whole screen just gets darker.
Or when screen pixels die, you just have black spots.
If that noise band is moving, it could also be noise from a closed caption line. -
If the bars are stationary and constant, then the matrix electronics are failing.
iPad 2 LCD Screen Jumping around/Scrolling/Typing
By SIRCOOKS in forum ComputerReplies: 0Last Post: 21st Jun 2013, 06:16 -
Powering 12" LCD screen with a battery - possible?
By Tsunamigirl in forum Newbie / General discussionsReplies: 5Last Post: 2nd May 2013, 21:15 -
Canon Gl2 - Flimsy LCD screen.
By GL2user in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 5th Oct 2012, 11:23 -
iPhone LCD Screen tester & Data Recovery
By SIRCOOKS in forum Off topicReplies: 0Last Post: 10th Sep 2012, 10:35 -
Toshiba TV - LCD Screen Issue - Please see video Clip and comment
By culttvguy in forum DVB / IPTVReplies: 4Last Post: 12th Nov 2011, 17:39
