Hi,
I have a problem in recording the encrypted channels?
I can not play video (TSV.file) on PC?
Unlike non-encrypted channels working without problems on pc
I used these programs : TSDoctor, tsMuxeR, Avidemux, TSDecryptor, tsdec_gui, but no avail
Knowing that the video file works in the receiver!
the type of my device : Dreamstar Dreamini HD3
H/W Version : HSP06G1S2_K
S/W Version : 1.2.2
Customer model: DREAMINI HD3
player MPC-HC x64 but the play audio only
Please! Is there a solution to this problem?
MediaInfo :
General
Complete name : C:\Users\Asus\Desktop\PVR\DISCOVERY-CABANES PERCHEES(20160827_113813)\DISCOVERY-CABANES PERCHEES(20160827_113813).TS
Format : MPEG-TS
File size : 26.9 MiB
Duration : 27 s 615 ms
Overall bit rate : 8 153 kb/s
Video
Menu ID : 9901 (0x26AD)
Format : AVC
Codec ID : 27
Duration : 27 s 600 ms
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 6
Channel(s) : 3+ channels
Compression mode : Lossy
Language : French
Audio #2
Format : AC-3
Format settings, Endianness : Big
Codec ID : 6
Duration : 27 s 584 ms
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 spf)
Delay relative to video : -861 ms
Stream size : 647 KiB (2%)
Language : qad
Menu
List : 110 (0x6E) (AVC) / 121 (0x79) (AC-3, French) / 123 (0x7B) (AC-3, qad) / 143 (0x8F) (DVB Subtitle)
Language : / French / qad
You will need to figure out the encryption key used by your STB to encrypt the ts files, then write a program to decrypt the packets.
Can you get more detailed info on the video other than what you have posted - normally MediaInfo shows more details... have you tried demuxing anyway?
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
you could spend the next year working on this and NOT solve the problem
the only thing that really works,
is to play the signal 'thru' an HDMI copy device that ignores HDCP
the device will copy/record the hdmi signals sent from the box to the TV, and create an mp4 HD recording, typically about 4GB per hour of video
you can then play that file anywhere, PC, tablet, media player .. etc..
you can't decrypt the files you have from the box, unless maybe you have access to Government grade decryption computers
TSV files - help
By espessim in forum Software PlayingReplies: 7Last Post: 10th Mar 2018, 18:42 -
How can you decrypt a file after it has been ripped.
By ROBO731 in forum DVD RippingReplies: 11Last Post: 9th Nov 2013, 22:59 -
burning non-HD content recorded on HD receiver
By kschwi in forum DVD RippingReplies: 38Last Post: 31st May 2013, 15:25 -
.tsv file that recorded from reciever 1080i
By farhadjokers in forum Software PlayingReplies: 20Last Post: 4th Nov 2012, 08:48 -
MP4 File - How to decrypt format?
By nymiezer in forum Video ConversionReplies: 5Last Post: 4th Aug 2012, 14:34
