Is there a good virtualdub filter chain for fixing videos that have very minor color casting?
It depends on the nature of the color cast. Not all color casts are the same, and the fix depends a LOT on the nature of the problem.
There is an absolutely amazing tool the StainlessS over at doom9.org just developed to fix color casts from faded film:
GamMac, Gamma Machine
If you skim through that thread you'll see some amazing results. -
What I'm looking for is something for VHS rips that look great except that they have some minor but noticeable color casting that might be related to chroma saturation. I also use an older computer with a mediocre video card that adds minor color casting to everything it rips, but it is only really noticeable on things that were VHS sourced
You could try Colormill:
Colormill Film Color Cast Corrections
This link shows it being used for film color cast removal, but it is a generic plugin and can be used to remove other types of casts. It is a free filter that works directly in VirtualDub.Last edited by johnmeyer; 27th Aug 2016 at 14:29. Reason: fixed link
Advice for fixing blue cast on Super-8 indoor film shot outdoors w/o filter
By bookemdano in forum RestorationReplies: 7Last Post: 3rd Jul 2015, 01:34 -
Remove a green color cast and globally improve a crappy DVD
By abolibibelot in forum Video ConversionReplies: 18Last Post: 6th Jun 2015, 17:00 -
VD Remote or VA Cast
By clayto in forum ComputerReplies: 0Last Post: 27th May 2015, 17:11 -
color correction help for green yellow cast
By mammo1789 in forum RestorationReplies: 0Last Post: 31st Mar 2013, 09:19 -
Any filter/plugins to auto detect equipment indicator light color change?
By zambri in forum Newbie / General discussionsReplies: 0Last Post: 1st Oct 2012, 11:38
