So I like using MediaCoder because it's one of the few GUI programs that can actually utilize NVENC for H.265 encoding.
However, when I convert videos down from 60FPS to 30FPS (for like a Facebook video or what have you), the filesize is still that of a 60FPS file. Anyone have any clue why that might be, or if it's just a bug with MediaCoder?
Attached is the MediaCoder preset I'm trying to use.
I don't use mediacoder, but a universal equation is
Notice FPS isn't in that calculationCode:filesize = bitrate * running time
In the xml , you have 5000 entered, probably kb/s
If the video bitrate was 5000kb/s for the original (video only, not counting audio or container overhead) the resulting filesize would be the sameCode:key="overall.video.bitrate">5000</node>
Well that setting isn't a target file size as far as I know, but you did make me curious about it, so I changed it to "Buffer Size" instead and that actually got me roughly the desired result.
With an original video at 3.38GB, I did one pass at 60 with buffer size 5000 which gave me a 353MB file. Another pass at 30 gave me a 215MB file.
No idea what the math is there, but it sorta worked.
Mediacoder now ransomware
By aedipuss in forum Latest Video NewsReplies: 29Last Post: 28th May 2016, 10:07 -
Mediacoder ERROR !
By vickynash in forum Newbie / General discussionsReplies: 6Last Post: 28th Jul 2014, 15:35 -
FLV Preset For Mediacoder
By jcool26 in forum Newbie / General discussionsReplies: 7Last Post: 7th Feb 2014, 15:39 -
Problems With Mediacoder
By ganymede in forum Video ConversionReplies: 6Last Post: 21st Mar 2013, 13:23 -
New Mediacoder with CUDA problems.
By Stears555 in forum Video ConversionReplies: 26Last Post: 11th Jan 2013, 22:44
