I am having a problem using the "build" function for a blu-ray video in Imgburn 2.5.8.0. What I do is start by dropping two m2ts files into the input list. These files were created by me using Hauppauge's Capture client from a PVR. Imgburn recognizes these files and prompts me on building a blu-ray video and I follow the steps. I have options correctly set to UDF 2.50. However, the disc I get out puts my video files into the BDMV root instead of the STREAM subfolder. Consequently, when i put it into a Blu-Ray player, it thinks there is no video there and thinks it''s a blu-ray DATA disc.
If I MANUALLY create the file structure instead, creating only a CERTIFICATE and BDMV folder, and then create a STREAM folder where I drag my m2ts files, would that work? Should I also manually create all the other (empty) folders?
Gary
				Results 1 to 11 of 11
	ImgBurn is not a Blu-ray authoring program. If you need the two m2ts files joined together, use the Append function in tsMuxeR, and output to Blu-ray structure before burning with ImgBurn.
 If these are two separate videos, then you'd need a menu to select each. You could use BD Rebuilder using the File-->Import-->Video Files path to import the two m2ts files and make a simple menu where you can select each one in the Blu-ray output. Again, you burn with ImgBurn.
	Actually, ImgBurn does TRY to be an Blu-Ray authoring program insomuch as you can give it TWO .m2ts files and it will prompt to create the full Blu-Ray folder structure, where none existed before, it's just that it's putting the .m2ts files in the wrong place. So if when you say "not a Blue-Ray authoring program" you mean it fails in that regard, you'd be correct. And if I give it only ONE m2ts file, it doesn't even TRY to create the folder structure, just ends up a data disc. Learning curve on tsMuxeR appears to be beyond what I am willing to tackle for this simple project today.
	I'm not sure it can be easier than using tsMuxeR. Add your first file, then click on Join to bring in the second. Set your Output to Blu-ray disc and specify where you want the output on the hard drive. Click on the button that reads Start Muxing.
 If your two m2ts files are encoded with the same specs, this should give you one seamless video, in Blu-ray format. Now, there is no telling from the information you've given that the output will actually be compliant to Blu-ray specifications. M2ts files are not necessarily made to match Blu-ray specs, and tsMuxeR will NOT re-encode them to be so. It just produces the Blu-ray structure, no matter what kind of video and audio your are trying to put in there.
 BD Rebuilder will re-encode to make them compliant, and give a menu to access each one, if you need separate videos.
 ImgBurn is a burning program and can make ISO files. It has never claimed to be anything else.
	tsMuxeR not working for me. I am giving it .m2ts files recorded at 8 Mbps, 1920 x 1080, 29fps, audio 192 kbps at 48 kHz. The files were generated by the codec in Hauppauge's HD PVR2 Capture application with component inputs. On import, tsMuxerR says "Unsuppported format--Some tracks not recognized, This track ignored."
	Here's my output: This is encoded by a Hauppauge PVR 2 Capture device.
 General
 Complete name : K:\Video\National Parks 3 1080i.m2ts
 Format : MPEG-TS
 File size : 7.52 GiB
 Duration : 1 h 53 min
 Overall bit rate : 9 522 kb/s
 Maximum Overall bit rate : 5 000 kb/s
 Video
 Menu ID : 1 (0x1)
 Format : AVC
 Format profile : High@L4
 Format settings, CABAC : Yes
 Format settings, ReFrames : 3 frames
 Codec ID : 27
 Duration : 1 h 52 min
 Bit rate : 8 858 kb/s
 Width : 1 920 pixels
 Height : 1 080 pixels
 Display aspect ratio : 16:9
 Frame rate : 29.970 (30000/1001) FPS
 Standard : Component
 Color space : YUV
 Chroma subsampling : 4:2:0
 Bit depth : 8 bits
 Scan type : Interlaced
 Scan type, store method : Separated fields
 Scan order : Top Field First
 Bits/(Pixel*Frame) : 0.143
 Stream size : 6.99 GiB (93%)
 Color range : Limited
 Color primaries : BT.709
 Transfer characteristics : BT.709
 Matrix coefficients : BT.709
 Audio
 Menu ID : 1 (0x1)
 Format : MPEG Audio
 Format version : Version 1
 Format profile : Layer 2
 Codec ID : 3
 Bit rate mode : Constant
 Bit rate : 192 kb/s
 Channel(s) : 2 channels
 Sampling rate : 48.0 kHz
 Compression mode : Lossy
 Delay relative to video : -25 ms
 Stream size : 155 MiB (2%)
	Ok, that looks like 1080i video using AVC (H264) video, which shouldn't be a problem. Your audio is MP2 however, and not on the list of audio types that tsMuxeR can handle. This is a bit surprising, since it was a reasonably common codec in DVD's. MP2 is not used in Blu ray.
	Over here, TSmuxer likes MP2 files. Possibly that audio stream was muxed incorrectly, and/or
 incorrectly flagged/identified as MP2 by MediaInfo
 I've already seen (and created as well) transport streams whose MP2 and MP3 audio tracks were detected as 'AAC' by MPlayer (which then played them either as silence or as noise).
	I can't remember the last video I had with MP2 audio, so its not something I've tested in tsMuxeR. The list I found may be out of date since you have had success with that type of audio and tsMuxeR. But there is something wrong if the program won't recognize one of the tracks. Mediainfo isn't showing an obvious problem with the video, so I looked for an error in the audio. He won't be able to use MP2 in a Blu-ray anyway, so I might start with demuxing the video and audio, then converting to AC3.
	You might take a look to the upper left on this page for 'WHAT IS' Blu-ray for the specifications, formats and structure of a BD compliant disc.
  Burning avi's, mp4's and mkv's to DVD/Blu-Ray using ImgBurnBy Ronnie_ASA in forum Authoring (DVD)Replies: 9Last Post: 22nd May 2016, 08:58
  Can't burn blu-ray discs using either Magix Edit Pro 2016 or ImgBurnBy Steelerfan43240 in forum Authoring (Blu-ray)Replies: 5Last Post: 20th Apr 2016, 15:01
  Burning Blu-ray Data Disc with ImgBurn.By bbanderic in forum DVD & Blu-ray WritersReplies: 25Last Post: 11th Oct 2015, 13:21
  ImgBurn and Blu-ray?By NLP in forum Blu-ray RippingReplies: 21Last Post: 27th Sep 2014, 11:21
  burning blu ray / hd videoBy coolrunner in forum Newbie / General discussionsReplies: 8Last Post: 14th Aug 2014, 21:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
