Guys, I've ripped cd library into wavs. The problem is that now every few hundred files I've got pink noise wavs which I have to delete (see attached wav).
Do you know any command line software, or any software which I can use for finding these pink(white) noise files.
The library is just massive.
Perhaps https://acoustid.org/ (software using this library) - alternatively SoX and power + level measurement with perhaps spectral analysis.
ffmpeg noise filter usage based on mplayer noise settings?
By Selur in forum Video ConversionReplies: 5Last Post: 21st Jun 2015, 08:19 -
The correct order for 6 channel wavs to encode to dts?
By coltonhelp in forum AudioReplies: 2Last Post: 18th Dec 2013, 19:38 -
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 08:26 -
DTS-HD MA 7.1 to WAVS (8 channels)
By monks19 in forum AudioReplies: 25Last Post: 28th Jan 2013, 14:30 -
Help - Split 6 Channels into separate WAVs
By stovk in forum AudioReplies: 6Last Post: 17th Dec 2011, 07:37
