Hi. The VOBs I'm working with at the moment comprise the main movie and an 'extra'. The main movie is 2h19m long and I'm trying to make a single VOB (I find single VOBs easier for editing/conversion). I used PgcDemux as per the first pic but it gave me two VOBs, one of 1h44m12s and one of 35m24s.
If I change the 'Mode' from 'PGC' to 'VOB id' you can see these approximate times (2nd pic).
Can someone tell me the reason I'm not getting a single VOB (of 2h19m) and if there is any way that I can?
My thanks for any help offered.
Not familiar with this program. Maybe the split is due to a 4 gb limitation.
It's because you checked the 'One file per VID' box. There are 2 VOB IDs making up the film. Uncheck it and you should get the entire movie. You came close to figuring it out yourself.
PGCDemux/DVDDecrypter not outputting complete Vob Id/Cell
By guest in forum DVD RippingReplies: 5Last Post: 18th Jan 2015, 00:46 -
Multiple VOB's to a single MP4 ??
By grady27 in forum Video ConversionReplies: 2Last Post: 24th Jun 2014, 08:10 -
Extract subs from a single .vob
By rhaz in forum Authoring (DVD)Replies: 4Last Post: 13th May 2014, 01:36 -
Issues demuxing VOB w\PGCDemux & VOBEdit
By kpic in forum DVD RippingReplies: 15Last Post: 2nd Oct 2012, 03:39 -
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 20:15
