Ola!
I'm making videos for my youtube channel every day, and i'm doing almost exactly the same for each of them. This is how it looks:
- I have a mp4 video that is around 5 hours long
- I record a clip of around 20 minutes out of that with VLC player
- I import the clip into Adobe Premiere
- I trim a clip of around 20 seconds from the 20 minute clip
- I add the 20 second clip in front of the 20 minutes clip (intro)
- I add an image overlay at the start of the clip (for 5 seconds or so)
- Export
Now this takes me about 1-1.5 hours and i feel like i can be more effective with this, but i'm not sure how ^^
For the last 2 days i've been playing around with AviSynth, trying to make a script that will do all this for me. Conclusion is that i can't get it to work, i guess i'm missing some experience with these kind of programs and programming.
Is there something else that might work for me? Or is the way i'm working now the way to go?
Don't expect a full step by step plan how to make this work better but a push in the right direction would be nice
Gr. Luffy![]()
Results 1 to 12 of 12
WhateverSource("5 hour clip.ext") #return(last) # enable this line to see the full video part1 = Trim(start_of_20_second_clip, five_seconds_into_20_second_clip) part2 = Trim(five_seconds_into_20_second_clip+1, end_of_20_second_clip) part3 = Trim(start_of_20_minute_clip, end_of_20_minute_clip) ovr = ImageSource("overlay.png") part1 = Overlay(part1, ovr, X=?, Y=?, opacity=?) part1 ++ part2 ++ part3
@Jagabo, Return(last) doesn't show me the frame numbers but adding he following and enabling them after Return(last) does:
#ShowFrameNumber(scroll=true, x=400, y=27, font="Arial", size=24, text_color=$ff0000)
#ShowTime(x=462, y=44, font="Arial", size=24, text_color=$ff0000)
Should I need them or am I doing something wrong? -
@Videobruger, i'm going to look into this!
Yeah, something like that i need! Only problem is that i couldn't get Avisynth to work with my mp4 files. I got it to play with ffvideosource("C:\eeuwww.mp4") but there was no sound. When i started searching i found out i probably need FFmpegSource but i can't get that installed, the Install manual (https://github.com/FFMS/ffms2/blob/master/INSTALL) is to much for meAlmost nothing in there makes sense to me.
Not sure if you can be of any help there? Would be awesome. -
I meant you could open the script in an editor that shows you the frame numbers (like VirtualDub). But using ShowFrameNumber() will work too.
You can eliminate the VLC step -- just load it directly into Premiere.
The time consuming part is identifying the parts of the clips you want to use. That's true whether you are using Premiere or Avisynth. At least in Premiere it's easier to see what you are doing. An hour to an hour and a half doesn't sound particularly unreasonable -- but see if you speed up after doing it a couple of times. -
I don't see how avisynth is speeding up your workflow for this task. It's not really automating anything in this scenario. I think it would be faster in premiere, especially if the 20 seconds were made of of separate edits (a non contiguous section). The navigation and editing are faster
The other time consuming part is re-encoding. Not only is there quality loss, it takes time, sometimes a long time - depending on your settings. Using a smart editor that supports "stream copy" like videoredo, solveigmm video splitter, tmpg smart renderer, etc.. will pass though the edits many times faster (basically limited by storage I/O transfer speed)
If you're doing it in avisynth, I would use l-smash instead of ffms2. l-smash doesn't require indexing of mp4, so you're going to save time and index clutter on each video
eg.
Code:v=LSmashVideoSource("C:\eeuwww.mp4") a=LSmashAudioSource("C:\eeuwww.mp4") AudioDub(v,a)
You can even let AviSynth calculate the 5 second overlay segment for you. Combining some of the above scripts:
Code:v=ffVideoSource("C:\eeuwww.mp4") a=ffAudioSource("C:\eeuwww.mp4) AudioDub(v,a) #return(ShowFrameNumber(x=20,y=20)) # enable this line to see the entire video with frame numbers part1 = Trim(start_of_20_second_segment, end_of_20_second_segment) part2 = Trim(start_of_20_minute_segment, end_of_20_minute_segment) part1a = part1.Trim(0, Int(framerate*5)) # 0 to 5 seconds part1b = part1.Trim(Int(framerate*5)+1, 0) # 5 seconds (+1 frame) to end ovr = ImageSource("overlay.png") part1a = Overlay(part1a, ovr, X=width-100, Y=height-100, opacity=1.0) # lower right corner, fully opaque part1a ++ part1b ++ part2
Heaps of raw footage, Program to splice & compress?
By fabes253 in forum EditingReplies: 12Last Post: 14th Jan 2015, 17:11 -
How to splice together separate 5.1 .wav audio files??
By JetrellFo69 in forum AudioReplies: 3Last Post: 23rd Dec 2012, 16:13 -
Convert BD ISO to MKV and maintain overlays?
By netmask56 in forum Video ConversionReplies: 2Last Post: 12th Feb 2012, 04:00 -
DV Workflow??
By anonymous_whatever in forum Newbie / General discussionsReplies: 14Last Post: 11th Feb 2012, 15:00 -
Looking for low cost editor that can make multiple cuts and splice
By jimdagys in forum EditingReplies: 4Last Post: 11th Dec 2011, 11:33
