  1. Hello
    Please check this sample
    I have used this setting in megui
    program --pass 2 --bitrate 1000 --stats ".stats" --deblock -1:-1 --keyint 240 --min-keyint 23 --b-pyramid none --ref 5 --qpmin 10 --qpmax 51 --vbv-bufsize 25000 --vbv-maxrate 20000 --me umh --direct auto --trellis 2 --output "output" "input"
    Is there any problem in my setting?
  2. Use more bitrate. Don't remove all noise before encoding, deband and add noise if necessary (GradFun3()). Use --aq-strength=1.6, 1.8 or higher. Use 10bit x264 (but you'll have limited playback options).
  3. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Those low bitrate artifacts look more like H.265 than H.264. Is the source of high quality, or a low bitrate x265 rip?
  4. And IMHO you need exactly opposite - you need increase deblocking not reduce it as currently there is strong blocking visible.
