I want to zoom into about 4-5 minutes of my video using Video Pad Editor, I suppose I mean magnify the central part. This is because the details are a little too far away.
But I don't know if it is Zoom or Magnify or Crop I should use! Any ideas welcomed.
rookkeeper
Avisynth appears to be something you can use on Videopad editor (Never used it but looked it up on internet.) I'd use Avisynth and the VD_Zoom.avsi plugin for Avisynth. This Plugin gives a lot of options for where to zoom in, how much, gradual zoom in/out, and a lot of other control for the zoom.
A script such as this is typical:
The settings are:Code:DirectShowSource("C:\PathToVideo\Video.flv") converttoRGB32() Import("c:\PathToZoom\vdub_zoom_alone.avsi") VD_Zoom(480,240, 240, 120, 100, 400, 84734, 85666, 0, 0, 0, "p_bicubic", 400, 100, 85667, 85700)
This gives a lot of options such as nice slow zoom in to double? size and then nice slow (or fast) zoom out.function VD_Zoom(clip clip, int "width", int "height", int "focusX", int "focusY",
\ int "start_per", int "end_per", int "start_Frame", int "end_frame",
\ int "red", int "green", int "blue", string "mode", int "start2_per",
\ int "end2_per", int "start2_frame", int "end2_frame")
PotPlayer - Zoom video region to full screen
By masster in forum Software PlayingReplies: 5Last Post: 22nd Nov 2015, 14:46 -
zoom (magnify) in video editing - newbie
By ben410 in forum EditingReplies: 1Last Post: 18th Jun 2015, 21:48 -
Ulead Video 11Plus pan & zoom
By jakhall in forum EditingReplies: 1Last Post: 24th Dec 2014, 11:54 -
How to convert *.mkv to *.avi with copy video part and re-encode audio part
By pxstein in forum Video ConversionReplies: 13Last Post: 1st Aug 2014, 11:24 -
Video techniques - shaking zoom in and zoom out effect?
By Mylo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Oct 2011, 12:08
