I have a few VOB files on my PC that I want to combine into a video, but they have 2 dubs.
I downloaded Audacity and ffmpeg for it, used vobedit to export the .ac3 sound files (clicked some demux option) and imported them into audacity. Problem is it's one sound file but it has 2 dubs inside it, so I don't know if audacity or some other program can "figure out" the difference in sounds and remove one of them :S
	You better hope these two "sounds" are one left and one right. If they are not, you are not "removing" one (an OVERdubbed language or whatever).
 Unless you are talking about two separate audio streams.
	If muting one tack doesn't work, try merging the two tracks into to one. If that gets you the wrong track language, go back to the start, invert one channel, then merge them into one.
  Ripping PS2 Sounds and music.By coondog1234 in forum AudioReplies: 10Last Post: 28th Jul 2016, 21:22
  my avi freeze but sounds keeps working.. HELPBy casperabm in forum Video ConversionReplies: 5Last Post: 25th Feb 2014, 21:10
  Separate sounds from AIFF fileBy Creed92 in forum AudioReplies: 2Last Post: 8th Dec 2013, 15:14
  Dorky Sound Sounds Good ThoughBy budwzr in forum AudioReplies: 2Last Post: 7th Nov 2013, 11:36
  Skype Mutes all other sounds when in call.By Jappyanime in forum AudioReplies: 3Last Post: 11th Sep 2012, 04:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
