I got some clips I can only decode with mencoder (due to it's vfw interface), when I use:
there is some color space mixup and I end with blue smurf like humans.Code:mencoder -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -noskip -vf scale,format=i420,scale,format=444p -nosub -nosound -mc 0 "F:\TESTCL~1\test.avi" | ffplay -an -sn -pixel_format yuv444p -video_size 640x352 -f rawvideo -
Problem seems to be with the 444p handling, because when I use:
colors are as they are supposed to.Code:mencoder -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -noskip -vf scale,format=i420 -nosub -nosound -mc 0 "test.avi" | ffplay -an -sn -pixel_format yuv420p -video_size 640x352 -f rawvideo -
Since I want/need 444p output the question is:
Does anyone know what pixel_format do I need to use in ffplay to handle the output or mencoder properly?
Cu Selur
Okay, got it the y&v planes got swapped somewhere and using:
fixes the issue.Code:mencoder -lavdopts threads=8 -really-quiet -of rawvideo -o - -ovc raw -noskip -vf scale,format=i420,scale,format=444p -nosub -nosound -mc 0 "F:\TESTCL~1\test.avi" | ffplay -an -sn -pixel_format yuv444p -video_size 640x352 -f rawvideo -vf swapuv -
So new question is:
Is this a bug in mencoder or ffplay/ffmpeg ?
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
[SOLVED]Use ffplay to check how much to brighten video before using ffmpeg?
By yetanotherlogin in forum EditingReplies: 1Last Post: 16th Mar 2016, 05:59 -
Help needed with ffmpeg/ffplay and select
By Selur in forum Video ConversionReplies: 2Last Post: 13th Aug 2014, 03:35 -
ffplay output-what is aq?
By Punchcard in forum AudioReplies: 2Last Post: 31st Jul 2014, 15:12 -
ffmpeg in pipe with mencoder
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2014, 12:30 -
Saving FFplay output
By qontranami in forum ProgrammingReplies: 6Last Post: 13th Feb 2012, 15:15
