Hi cat, please consider my commandline
Code:v:\automazioneclip\core\ffmpeg.exe -threads 12 -y -i "%~dp1%~n1.avi" -c:v libx264 -profile:v high422 -level:v 3 -g 33 -bf 2 -crf 22 -flags +ildct+ilme -top 1 -pix_fmt yuv422p -vf scale=interl=1:in_range=tv:out_range=tv -af "pan=stereo:c0<c0+c1:c1<c0+c1" -c:a ac3 -b:a 320k -ar 48000 -aspect 16:9 "%~n1_Mp4_PanPotYES_Remux64bit.mp4"
nut now I like to improve de audio quality bitrate codec, possibily to bring it a 516 Kb/s if possibile. How can I do? thanks
#1. Re-encoding to lossy codec loses quality! You don't "improve" quality with higher bitrate, you only lose less quality.
#2. Ac3, like many similar cbr lossy codecs, doesn't allow just any arbitrary bitrate option. There are TIERS based usually on mod16 numbers (32, 48, 64, 96, 112, 128...). 512 is ok, but 516 is not. Then there are limits based on # of channels, and whether it is for dvd, bd, broadcast, generic, etc. 2 ch max for ac3 is likely 320kbps, which should basically be transparent compared to uncompressed.
#3. You ought to know this by now.
From one codec to another with same bitrate, quality loss?
By MovingParts in forum AudioReplies: 11Last Post: 27th Mar 2016, 01:55 -
Direct Stream Video - But Keep Audio Codec & Change Bitrate in an MKV file
By TheRandomOne in forum Video ConversionReplies: 1Last Post: 4th Jan 2016, 22:00 -
Improving this audio track?
By yetanotherlogin in forum AudioReplies: 5Last Post: 23rd May 2014, 18:39 -
Bluray Audio Format Supported - And what is minimum audio bitrate?
By VideoFanatic in forum AudioReplies: 13Last Post: 9th Jun 2012, 16:22 -
multiAVCHD audio bitrate?
By morghe-sokhari in forum Newbie / General discussionsReplies: 0Last Post: 16th Feb 2012, 09:11
