Hi, hope someone will advise me which they think is the best software to buy on disc to copy region 1+ region 2 copy iso from a disc then copy from my Nero software, I did use T D MORE but I cannot renew , not available. Please can anyone advise me on this. Thankyou in advance. Frank.
There are three companies to consider for decryption if you need an up to date program. There are many older programs that still work for the majority of DVD's, but will not work with those that have extra protection.
DVDFab, Redfox AnyDVD and MakeMKV are three of the best for decryption, but if you are working only with DVD's, I would avoid MakeMKV even though it is free, since it will only decrypt DVD's as MKV files, and you lose the menus and extras.
Which leaves DVDFab and AnyDVD. Fab can decrypt and rip and also gives the option to compress your movie if you want to fit it onto a single layer disc. Fab has a free component that is supposed to work even after the trial ends. It is called DVDFab HD Decrypter, but it lacks the compression capability, or the ability to rip as an ISO.
AnyDVD will only decrypt and rip. It will not compress anything.
Both DVDFab DVD Copy and AnyDVD can output to ISO files if that is what you want. -
how does the copy protection work on a copy of the copy protected tape?
By opie390 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2014, 19:18 -
Should non Standard Copy Protected DVDs use the "DVD Video Logo?
By TubeBar in forum Newbie / General discussionsReplies: 10Last Post: 23rd Sep 2013, 18:20 -
Copy 250 DVDs to hard drive
By karenlorr in forum DVD RippingReplies: 36Last Post: 1st May 2013, 10:04 -
Poor sound when trying to play DVDs and Blue Ray DVDs on my computer
By peterjh in forum ComputerReplies: 9Last Post: 26th Dec 2012, 11:13 -
Using DVDFab to copy DVDs to my Hard Drive a good place to start ?
By Bluelude1 in forum DVD RippingReplies: 29Last Post: 24th Nov 2011, 20:26
