If there is a problem you best bet is probably to post the issue over at https://github.com/rigaya/VCEEnc/issues to let rigaya (the author of VCEEnc) know, since afaik both StaxRip and Hybrid use it as back-end for the encoding.
Cu Selur
Ps.: my RX 470 died on me, so I can't test myself. (not aiming to buy a new one since the AMD card just caused problems in my system)
Results 151 to 157 of 157
I just updated to 17.7.2 and VCE definitely still works fine, I've been streaming no problem using the GPU to encode in OBS. The OBS plugin uses AMD's AMF framework to talk to VCE. I'm assuming VCEEnc and therefore staxrip/hybrid do too?
[edit] I also just encoded something in A's Video Convertor and it completed with no problems; A's uses MFT. MFT and AMF are the only ways to talk to VCE on windows, so... -
I'd talk to the VCEEnc dev then, sounds like he has a dodgy implementation of AMF.
A "budget" Nvidia card for H265 hardware encoding
By agatek in forum Video ConversionReplies: 37Last Post: 16th Oct 2019, 08:12 -
AMD Retires Catalyst Control Center, Introduces Radeon Software Crimson
By mikel in forum Latest Video NewsReplies: 1Last Post: 3rd Nov 2015, 23:47 -
AMD Radeon HD 8650G + 8670M Dual Graphics HDMI 1.4 stereo support?
By TB2XSBW in forum Media Center PC / MediaCentersReplies: 0Last Post: 22nd May 2015, 15:38 -
H265/HEVC samples
By deadrats in forum Latest Video NewsReplies: 51Last Post: 23rd Mar 2015, 02:15 -
H265 encoding on Solaris
By tola5 in forum Video ConversionReplies: 3Last Post: 8th Feb 2015, 21:29
rigaya's VCEEnC doesn't work...
