I am looking for any advice on caping HDTV, What Hardware/software & settings should I use.
Current Setup
(7)18.4GB Ultra160 CHEETAH's in raid 5
(2) AMD 2000MP's
2gig 333DDR Ram
ATI AIW 8500
WinXP Pro / Red Hat
DVR-A03
Money is not realy a problem
I don't think you can. The AIW 8500 probably only captures at 640x480; hardly HDTV resolution. It will look great anyway though.
As for software and settings, read the FAQs and guides. -
There are no consumer formats (aside from DV maybe) that can reproduce the quality you'll get from over-the-air high definition digital television. Furthermore, most American television stations broadcast most of their schedule in standard definition digital television, which is DVD resolution at a higher bitrate.
You'll need an HDTV tuner/capture card to even pick up the over-the-air signals, as they are broadcast in a vastly different part of the spectrum than analog TV is (analog TV is broadcast, in the United States, on either side of the FM radio spectrum space). If you have an HDTV tuner card (the only one I remember seeing was made by Hauppauge), you should be able to use your current capture software to capture at any resolution your computer can handle without dropping frames. That may very well be 640x480. -
There are 3 HDTV capture cards I know of: HiPix, Hauppauge and one other Accesstv?
They all differ, but the HiPix card allows recording AND you can reportedly convert the rather large recordings into MPEG using a freeware program.
The HiPix software is also being modified by users to fix bugs and extend its capabilities.
See http://www.avsforum.com/avs-vb/ -
tazzofemarr,
since no one else has said nething i'll say it, nice rig, like the one i'm going to be building soon. out of curiosty how much did that bad boy cost you? and what the hell are you using that for?
advice on hardware to play HDTV captures
By halsboss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 29th Aug 2009, 08:07 -
Upgrade to HDTV advice
By stuntmaster in forum DVB / IPTVReplies: 4Last Post: 15th Oct 2008, 18:50 -
NEW HDTV advice PLASMA or LCD
By efiste2 in forum DVB / IPTVReplies: 102Last Post: 1st Mar 2008, 11:03 -
hdtv issue with dvd/vhs combo - advice needed !
By Dan of Troy in forum DVB / IPTVReplies: 3Last Post: 24th Nov 2007, 13:54 -
Enigmavision HDTV - HDTV viewer software for ATSC TV tuner cards.
By gc04 in forum Latest Video NewsReplies: 9Last Post: 7th May 2007, 01:32
