    Jul 2016
    Pacific Palisades, CA
    I have a video file and I'm trying to figure out if it's ProRes 422 HD or just ProRes 422. Is there some sort of open source software that identifies codecs?
  2. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
    Jul 2016
    Originally Posted by ron spencer View Post
    Perfect!
    1 video stream: ProRes
    I wonder if it would say "Pro Res (version 0) (422)" if it was an HQ profile file.
  4. Change the View to Text mode. You'll get a lot more information. It may tell you the chroma subsampling.
  5. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Good Tip!
  6. Member Cornucopia's Avatar
    Note that you said, "codec used for a file"...
    Believe it or not, with a few exceptions*, there's NO way to tell which codec WAS used or which codec TO use.
    What is written in the file (headers) is a denotation of the format/standard that the file was encoded to.
    So, for example, you will see a file encoded to h264 (aka AVC, aka MPEG-4,Part-10). What you won't see is "this file was encoded using Adobe Media Encoder" or "this file should be decoded by Corel/WinDVD Mpeg decoder".
    IOW, the type of tool is important (philips screwdriver for philips screws), but not the brand/implementation (swiss army vs. Black & decker ratcheting screwdriver vs. Kyobi power drill w philips bit).
    *Some codecs add encoding parameters into the metadata, such as x264. And some formats might only have one encoder/decoder implementation option.
