I've been playing movies over using VLC from my PC to my TV for years, using sp/dif for the audio to my 5.1 amp. Suddenly on one film there is no DTS audio over SP/DIF. All other movies play fine and i can find no substantive difference in the audio specs using mediainfo.
I did reencode to 5.1 ac3 in audacity (custom mix enabled) and the audio does now output to my amp, but for some reason the blue light indicating 5.1 still doesn't come on. (I double checked and mediainfo indicates 6 channels).
Any thoughts/possible explanations for either?
Thanks.
Well, that's not relevant. Just as an example, the DTS track may be 'little-endian', and your TV's firmware was designed to deal only with 'big-endian' DTS...
I don't use Audacity, so I don't know what "custom mix enabled" means. To the best of my knowledge, converting multichannel audio from one format to another format doesn't require any "custom mixes" or downmixes.Last edited by El Heggunte; 18th Aug 2016 at 19:25. Reason: clarity
Thanks for the replies.
El Heggunte - many a time mediainfo has highlighted the reason for audio playback problems. The fact that it isn't now is the problem. But i'll check into "endian" because it's a new one on me. Any other examples? Custom mix is necessary in audacity to reencode 5.1 DTS to 5.1 ac3, otherwise it will downmix to stereo - i merely wanted to indicate that i had not made that mistake.
Pandy - i know it's not a standard. But on my sony amp it comes on when it recognises 5.1 and it's not doing so in this instance. So although mediainfo tells me it's 5.1, my amp is telling me that it isn't. -
How come you're using Audacity to convert DTS to AC3 and not ffmpeg? All you should have to do is run the command line pipes and remux them back into an .mkv container with MKVToolNix GUI.
Place it in C: drive. Go to command prompt and enter:
cd C:\ffmpeg.exe -i <location of source file> -vcodec copy -acodec ac3 -ab 640k -ar 48000 -ac 6 <output location>.ac3
This will produce an AC3 5.1 640kbps audio file. Then just remux it back in to the original. You can also change "640k" to 448k or 384k if you don't need the full 640 rate.Last edited by stonesfan129; 24th Aug 2016 at 10:26.
Hope you configured your player to output RAW AC3 over S/PDIF - normally software trying to produce PCM (to apply additional processing) - player must be capable to output AC3 stream directly to S/PDIF (and whole system with drivers capable to do so as well).
You can try to record some test DVD to verify this (or hook audio card S/PDIF input capable to create some S/PDIF analyzer - perhaps your amplifier is able to display what is at the input - if PCM then definitely there is issue). -
I haven't configured the audio in VLC. I right-click on the screen audio>audio device>SPDIF interface. And the sound comes out of my 5.1 speakers. MusT have done this 100s of times over the years. Just this one film won't work with DTS at all or without recognising 5.1 with ac3.
How to convert DTS-HD / HDMA With bitrate 1509kbps to DTS 755kbps ?
By PrinceSwaraj in forum AudioReplies: 16Last Post: 17th Apr 2018, 15:21 -
dts 1509 to dts 755
By nixiejames in forum AudioReplies: 9Last Post: 25th Mar 2016, 11:00 -
DTS-HD MA vs. DTS Core for Concerts?
By adzyu100 in forum Blu-ray RippingReplies: 7Last Post: 9th Dec 2014, 08:57 -
how to make DTS 2.0 & DTS 1.0
By mkvonly in forum AudioReplies: 28Last Post: 22nd Jan 2013, 10:11 -
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 16:25
