Both are 16x DVD-R, MID TYG03, Made in Japan. One has part # J-DMR-JVC-IJB-SK , the other J-DMR-WPP-SK16 .
Taiyo Yuden (JVC) quit making optical discs back in December of 2015. They sold their formulas and mid codes to CMC Magnetics.
The J-DMR-JVC-IJB-SK seems to be old stock, made in Japan by TY.
The J-DMR-WPP-SK16 is also an old part number, and may be old stock. You'll need to look on the label to make certain that they are made in Japan. The new, CMC discs using the TY technology have a similar, though slightly different number T-DMR-WPP-SK16, and will have Made in Taiwan on the label. See the bottom of this page: http://www.mediasupply.com/tydvdwp16x100.html
Since both of the numbers you listed are TY G03, there will be very little if any difference in their construction or burning qualities. Both seem to be hub printable versions.
Victor/JVC/Taiyo Yuden shutting down optical disc business
By Kerry56 in forum MediaReplies: 13Last Post: 19th Jun 2015, 22:22 -
A question about Taiyo Yuden.
By wtsinnc in forum MediaReplies: 18Last Post: 13th Jan 2013, 05:03 -
Looking for the Taiyo Yuden CD-R's that have that blue look.
By happydog500 in forum MediaReplies: 9Last Post: 8th Jan 2013, 21:44 -
Taiyo Yuden 8X 8.5GB Dual Layer DVD-R?
By redwudz in forum MediaReplies: 22Last Post: 22nd Oct 2012, 21:21 -
BDR-206 and Taiyo Yuden
By ccarag in forum DVD & Blu-ray WritersReplies: 20Last Post: 2nd Oct 2011, 12:54
