hi friends
i dont know if this is the right place or not, so i request to the mod to move the post to its required place,
my problem is little weired, i have a 7.1 home theater, Yamaha rxv677 amp, samsung blu ray player BDE6500, jamo speakers, etc etc, whenever i play any blu ray which has 7.1 channel output my amp shows 8 channels which works perfectly fine, and when i play downloaded movies from torrent in 5.1 they works fine too, but when i download 7.1 channel torrent mkv file and play them vis samsung bd player my amp shows 6 channels only (5.1), whereas the uploader says the mkv video has 8 channel and 6 channels, then why my amp shows this?
my bd player settings is in BITSTREAM (Uncompressed) and NEO is off,
please help me what wrong settings i have
	1) check the properties of that MKV file with MediaInfo; also consider that a) you MAY have misunderstood what the uploader said, OR b) the uploader MAY have lied to you;
 2) read the forum rules again: https://forum.videohelp.com/threads/72386-Forum-rules-Acceptable-Use-Policy-(AUP)?
	i have downloaded mediainfo and saw the details of the file and it says:
 4659 kb/s / 1 509 kb/s / 1 509 kb/s, 48.0 khz 24 bits, 8 channels / 7 channels / 6 channels, DTS (MA /ES Matrix / Core)
 (Sorry for such post but its really annoying for me because people says to set BLU RAY Player to Bitstream and PS3 to PCM
	It may use core i.e. 5.1 audio - try to encode track in something like 7.1 aac.
	Is the player you're using compatible with DTS-HD Master Audio 7.1? If it isn't, that could be what's causing it to play the DTS 5.1 track instead. Is it possible the DTS 5.1 is set to default instead of the DTS-HD stream?
  Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28
  Video Conversion/Compatibility Question flv->Win Media Player, Mac PlayerBy charlestek in forum Video ConversionReplies: 7Last Post: 18th Nov 2014, 15:05
  Does it Exist: BluRay Player + USB Media MKV/MP4/AVI/DIVX Player + Youtube?By elgrayso in forum DVD & Blu-ray PlayersReplies: 14Last Post: 29th Jan 2014, 23:24
  Using a portable USB powered BD player with a Western Digital Media PlayerBy David S Graham in forum DVD & Blu-ray PlayersReplies: 4Last Post: 13th May 2013, 13:53
  Windows Media Player or K-lite codec player - Change Audio DeviceBy bsamual03 in forum AudioReplies: 2Last Post: 11th Feb 2013, 15:28
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
