Hi, first post here.
I imported a few GoPro videos into Movavi and wanted to tweek the sound a bit, so exported the project as a WMV so I could import it into my DAW (Mixcraft) and easily edit the audio. All went fine there and then I exported the edited audio as a Wave file and imported it into Movavi editor and the file was longer than the video and out of sync.
I tried again, exporting the audio from Mixcraft as a MP3 with the same result.
However, I then imported the WMV file back into Movavi and the wave file matched and was synced
Any ideas why this is? Thanks!
Analyzing the original file, the WMV and the WAV file should give the answers. We don't have access to them so it is up to you.
The problem is with Mixcraft ... audio not connected to video stream and being edited separately can lead to distortion in time length mismatch.
In this case you'll need to use another editing tool that can either keep time length match with included edits for remuxing with video source.
Or have a difficult job re-syncing the end product.
Merging audio with different video length headache
By Freelife2345 in forum AudioReplies: 7Last Post: 7th Mar 2015, 22:28 -
VOB file displays "1 sec" length, is actually 29mins, plays full length but
By neonnebula in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2015, 20:12 -
merging audio and video of different length
By Freelife2345 in forum AudioReplies: 15Last Post: 20th Nov 2014, 01:55 -
Audio/Video length not matching. Can I fix this in vegas?
By doomplug in forum EditingReplies: 1Last Post: 25th Sep 2012, 15:30 -
Video and Audio different length
By pchan in forum AudioReplies: 3Last Post: 15th Aug 2012, 03:46
