Does anyone know if it is possible to upgrade or hack DVD player so that it can play SVCD.
I heard that there are some codes??
Does anyone have information or link about that.
Thanks for replies.
It's not a hack. To be able to play a SVCD, there has to be a SECOND laser in the DVD to be able to read the CD (different wavelengths). No amount of hacking will produce a laser where one doesn't exist.
if your player support cdr/cdrw and vcd you could try this trick
http://www.geocities.com/newestmoviesencode/dvdvcd
if not buy a new dvd player or convert the svcd to vcd.
How to enable Packed bitstream
By john111 in forum Video ConversionReplies: 8Last Post: 4th Jan 2010, 15:17 -
enable desktop composition
By pazer in forum Capturing and VCRReplies: 0Last Post: 13th Apr 2009, 07:00 -
By pazer in forum Capturing and VCRReplies: 2Last Post: 26th Jan 2009, 14:02 -
How To Enable PC To Read DVD-R
By Jjay in forum Authoring (DVD)Replies: 10Last Post: 5th Jan 2009, 17:47 -
Enable Cookie Failed
By evol ecallaw in forum ComputerReplies: 14Last Post: 4th Jul 2008, 22:28
