    Aug 2016
    Canada
    Looking for a program that can join or split 24bit/192khz and 24bit/96khz files losslessly.
  2. Audacity.
    Note that since FLAC is a lossless format you can also just decode to uncompressed wave, edit in the wave editor of your choice and then re-encode to FLAC without any quality loss.
    Aug 2016
    Canada
    ok thanks for the help!
