Hi All,
Would appreciate any clues here, if you look at image of VOB2MPG window everything looks as I expect. The data on the files created shown in file explorer image though show 2 files are about half the length of the source, though they are size as expected as if they were normal length.
VLC player confirms the short length.
Any ideas?
cheers
Results 1 to 11 of 11
So this is a TV Show series DVD/set? How many episodes are listed on the cover?
Doesn't say what the title is, so there's always the possibility of multi-angle, seamless branching, 3d muxed elements, etc. Any of those could account for the difference.
Scott -
Here is the view from DVD Decrypter, doesn't this mean it's not encrypted?
Have used VOB2MPG successfully on other discs from the same box. -
Just tried ripping to hard drive with DVD Decrypter then used VOB2MPG, same result, ie 2 files with video half length.
Just tried processing one of the offending mpgs with Video Redo "Quickstream Fix" and it fixed the vid length issue.
So it looks like it is sorted? Anyway another way you could do is to simply using the original DVD and use MakeMKV and see how many titles it throws up and the lengths..
Joined MPG files & the video length is not showing correctly
By TheRandomOne in forum Video ConversionReplies: 2Last Post: 25th Apr 2014, 10:39 -
DVD not ripping correctly? .VOB files aren't the correct length.
By architectofpain in forum DVD RippingReplies: 12Last Post: 13th Nov 2013, 01:22 -
Weird video problem with some MKV files
By carlmart in forum Video ConversionReplies: 19Last Post: 24th Jan 2013, 19:09 -
video length doesnt show in vlcPlayer after merging few files with vobmerg!
By spiderMan007 in forum EditingReplies: 1Last Post: 17th Aug 2012, 13:38 -
manually copied of .MTS video files back to Panasonic HDC-90 memory card
By Rovi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 12th Jan 2012, 13:17
. Then use
