Okay, I have a few questions. I have both of these programs obviously, and I tried to figure out how to use CCE today, and that was a mess. I followed the guides step by step, and made the .avs file with all the information and such....but when I tried to load it into CCE it said
"Frame size 944x56 not supported. Supported frame size is up to 720x576" any suggestions? Also I was wondering if there is a method to run more than 2-pass with TMPGEnc, I haven't found one as of yet, and I want to run more than 2-pass to get that extra bit of quality in, unless I can figure out how to use CCE, which isn't looking good. ANy suggestions?!?! :D
ummmm, lower the frame size. It tells you in the manual that 720x576 is the max frame size/but when I tried to load it into CCE it said
"Frame size 944x56 not supported. Supported frame size is up to 720x576" any suggestions?"
No there isnt. Well somebody supposedly came up with a hack, but I have yet to see it work consistently if at all.Also I was wondering if there is a method to run more than 2-pass with TMPGEnc,
I have a NTSC DVD-rip guide for CCE if you want it. just email me. -
You try to encode Avisynth's error message.
For more details play the .avs with media player.
AVI to DVD MPEG (CCE or TMPGenc encoders)
By DJRumpy in forum User guidesReplies: 674Last Post: 15th Oct 2010, 07:46 -
TMPGEnc DVD Author 2 questions
By siluet in forum Authoring (DVD)Replies: 15Last Post: 27th Apr 2009, 20:57 -
Looking for an MPEG-2 Encoder like CCE and FFMPeg Questions
By Maikeru-sama in forum Video ConversionReplies: 85Last Post: 31st Aug 2008, 23:24 -
Questions about CCE, H264 and AviSynth
By Maikeru-sama in forum Video ConversionReplies: 18Last Post: 21st Dec 2007, 20:38 -
Some questions on TMPGEnc DVD Author 3
By rock_king_my in forum Authoring (DVD)Replies: 4Last Post: 7th Dec 2007, 06:32
