A lot of times I find subtitles that are the wrong framerate. So I try to transform the framerate to 23.976FPS which is the video's FPS in the media info. But there's no change, the subs are still out of sync (not time shifted). I save them as a SRT because that's the type I need for Aviaddxsubs
Windows 10, MPC-BE
Try change it with Subtitle Edit. If it wont work then try the Syncronizations features in Subtitle Edit. Like Visual or Point Sync.
I will try that for other subtitles. Right now the problem is that the subtitle and video I have are the same rate, and yet the subs are increasingly out of sync as the video progresses. They are both 23.976 so I'm not sure what to do. I don't know how to use the visual sync
Windows 10, MPC-BE -
Okay this is great thanks. It was hard to adjust it at first but trying half a second at a time helped perfect it.
Windows 10, MPC-BE
Aegisub won't let me print "%"?
By user115 in forum SubtitleReplies: 14Last Post: 26th Dec 2015, 18:35 -
VirtualDubMod - Problem - Null Transform Filter
By Cunhambebe in forum Newbie / General discussionsReplies: 9Last Post: 29th Mar 2014, 21:34 -
Scrolling under aegisub
By Patapin in forum SubtitleReplies: 0Last Post: 7th Dec 2013, 09:51 -
A box to do grayscale transform on a video signal?
By oknowgo in forum Capturing and VCRReplies: 17Last Post: 24th Aug 2012, 15:45 -
How to create logo using aegisub
By Mildragon in forum EditingReplies: 2Last Post: 25th Oct 2011, 04:28
