hi there,
i want to convert .ass subtitle format to ".SUP",
someone tell me to use easySUP, but i have this error with it.
Can any one help me, please?
				Results 1 to 16 of 16
	"some error with it" is not sufficient information.
 Please post a screen shot of the error message.
	EasySUP can do it. Appearently there are faults in your .ass.
 Perhaps Subtitle Edit handles it better.
	Looks like the .ASS file does not use Unicode (i.e., UTF-8 or UTF-16) — which is a very-bad idea.
	My bad, I was wrong, I wrote that before downloading the attachment.
 The ASS file seems OK (UTF-8)... BUT...
 AFAIK, that's not appropriate for Blu-Ray .SUP streams. The resolution should be either 1280x720 or 1920x1080PlayResX: 640
 PlayResY: 480
 Also: just to be on the safe side, convert from UTF-8 to UTF-16 (with Aegisub itself, for example), and see if EasySUP deals with it correctly this time
	Well, actually it is UTF-8 encoded. However there's some overlapping timecode and others so I opened it in Subtitle Edit and used Tools -> Fix common errors
 and then
 File -> Export -> Blu-ray sup
 And while doing so EasySUP finished without errors using the unedited original file?
	Is that disk unit (D: ) configured to give "full rights" to non-adminsit's supposed to produce a SUP file on partition D, but i got nothing.
 Normally only programs running with admin privileges (i.e., "run as administrator") have full writing access to the root directory of a disk unit.
	Not really as it works fine here (Vers 0.5) - even with the wrong time codes.can u help me to know what's problem with my application?
	i have tried Subtitle Edit but it deletes all tags and and make fonts very large,
 EasySUP was better on every thing, but i don't know what is the problem with it.
 i hope i can get help here or anyone guide me where to ask others.Last edited by Mustafa Kh; 16th Aug 2016 at 06:43.
  Is it possible convert DVD format to mov file?By joshua min in forum Video ConversionReplies: 3Last Post: 12th Aug 2013, 05:46
  How to convert subtitle file into .CAP format?By Valerc in forum SubtitleReplies: 11Last Post: 30th Nov 2012, 13:54
  Correct SSA/ASS subtitles with Format FactoryBy Budman1 in forum Latest Video NewsReplies: 4Last Post: 12th Oct 2012, 09:20
  How to use Subsync 1.5 to change format from .ass to .srtBy Mia96 in forum SubtitleReplies: 4Last Post: 24th Jun 2012, 05:26
  How can I Embed subs in ASS format?By Djard in forum SubtitleReplies: 5Last Post: 13th Jun 2012, 19:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
