Results 1 to 9 of 9
  1. Hello
    Please check this x264 setting
    level=4.1:mixed-refs=1:vbv-bufsize=78125:vbv-maxrate=62500:rc-lookahead=40:qpmax=51:qpmin=10:ref=5:direct=auto:b-pyramid=none:me=umh:trellis=2:deblock=-1,-1
    Where i am wasting cpu? i use this setting to encode 720p@950kb/s
  2. me and subme are some of the biggest consumer of encoding time.
  3. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Could probably save some time by using trellis=1 instead of trellis=2.
  4. Originally Posted by jagabo View Post
    Hello
    As i know subme and me has big impact in quality ( on low bitrates)
  5. Originally Posted by KarMa View Post
    You think it has low impact on quality?
  6. Originally Posted by ben45 View Post
    That wasn't your original question. If you want the best quality, what do you care how long it takes.
  7. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    It has a higher CPU demand for just a small benefit. I would just stick with the x264 presets if I were you.
  8. Thank you guys
    You helped me a lot
    Dec 2005
    Pocatello, ID
    If you really want to go 720p at 950kbps then you had probably better leave Trellis=2 and UMH. Might as well go L3.0, too.
    My recommendation would be to just about triple the bitrate, depending on your source.
