Which is better? Assuming both are lossless.
The DVD structure (VOB files inside a VIDEO_TS folder) is inside the ISO image.
Stop talking about VOB files. VOB files are useless(and not a DVD) outside of their VIDEO_TS folder. -
Moviegeek has the right idea about use determining the ripping format.
VOBs don't always play back correctly without a complete DVD file/folder structure, and ISOs are often problematic for streaming over a home network or playing the video with a hardware-based media player. Ripping a DVD to MKV file(s) with MakeMKV may make more sense for some people than ripping to either VOBs or ISOs. -
I experimented using MakeMKV on a DVD for upload to YouTube. What I wound up from this 23.976fps film with pulldown was a 29.97fps video on YouTube with every fifth frame a dupe (I downloaded it to check what was going on). Not what I had in mind, although I suppose I should have expected that. I'm not sure software or hardware players will play an MKV made from the DVD as they would the DVD itself. I then experimented with stripping the TFF/RFF flags and returning the M2V to its original 23.976fps, muxed it into an MPG, reuploaded it, and all was good with framerate and aspect ratio.
The upshot of all this is that I doubt, for NTSC people, using MakeMKV on film DVDs is such a good idea. Since all I cared about was what happened with an MKV from MakeMKV on YouTube, I didn't investigate any further.
I also agree with MOVIEGEEK if by 'VOB files' bitrape means the complete DVD and not just the VOBs. hech54 and usually_quiet are absolutely right about that. -
I recommend ripping to a MKV file instead. The files seem to turn out a tad smaller than an ISO. I'm not exactly sure why.
Play ISO or VOB Video Files on Samsung Galaxy S4 Phone and Note 8 Tablet
By Jerry22 in forum Newbie / General discussionsReplies: 3Last Post: 10th Jul 2015, 01:43 -
Do you rip/encode DVDs into separate AppleTV, iPad and iPhone m4v files?
By bobogs in forum DVD RippingReplies: 3Last Post: 24th Sep 2014, 11:42 -
Rip DVDs and Blu Rays to DVD Quality Files
By imthewalrus79 in forum Video ConversionReplies: 6Last Post: 19th Dec 2013, 03:54 -
How do I extract VOBs from an ISO file? (ISO to VOB?)
By Tearren in forum Video ConversionReplies: 6Last Post: 24th Jul 2013, 22:53 -
Best software to rip DVD into ISO files?
By guy24s in forum DVD RippingReplies: 2Last Post: 11th Oct 2012, 10:46
