What is VHS resolution
I mean like VCD is 320/240.
SVCD is 480/480
I am encoding some still pics as AVI's. Shall I go with VHS or DVD resolution?
Results 1 to 12 of 12
actually VHS doesnt have a resolution as far as i know
it uses a film which is unrestricted to resolution. most ppl are saying its a 320x240 resolution cuz its comparable quality. some are better, some are worse, but whatever. -
strictly speaking it is 480 interlaced lines, wich is like 360 progressive lines (these are visual anoligies) so its usually better than vcd and worse than svcd.
I wonder what a VCD at that resolution would look like.
IT would be like SVCD quality but using MPEG1
that would make it xVCD...no?
therefore, the amount of time you can fit on one cd is variable...
dig
THIS IS HARDCORE -
On 2001-07-29 22:03:59, Greg12 wrote:
Then what is 640x480?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
In a way, you're talking apples and oranges, Greg, as televised video is usually measured in lines of resolution while computer video is measured by pixel count. However - 640 x 480 is the size of a "full-screen" computer monitor video, which is usually scanned down to NTSC- or PAL-quality video. In the case of VHS-quality NTSC, you're looking at 126,000 pixels (240 lines horizontal resolution x 525 lines of vertical resolution) at 59.97 fields (half-frames) per second, while full-screen computer video has a resolution of 307,200 pixels (640 lines across x 480 lines up and down) at 60 full frames a second. (For some reason that escapes me, horizontal resolution on televisions, VCRs, etc. is measured *vertically* on a resolution chart.) That means that a 640 x 480 screen gives you 585 lines of horizontal resolution, which is better than most current broadcast television is....
Confused yet? Think of how *I* feel - I have to live with this! <g>
Best,
So when I put a movie into my VCR and hit play, what am I seeing?
I want to do an xvcd that will have the height and with of a VHS movie. -
try 640 x 480 -
Or 704x480, in computer pixels this tends to scale to TV well (double VCD res of 352x240).
Capturing SVHS using a standard VHS VCR - Is it possible?
By DJ Kris in forum Capturing and VCRReplies: 15Last Post: 4th Jul 2020, 12:00 -
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 12:50 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
TBC outputting standard VHS as SVHS?
By justin81 in forum Capturing and VCRReplies: 2Last Post: 21st Jun 2008, 13:50 -
What bitrate to rec standard VHS?
By jsmithepa in forum RestorationReplies: 31Last Post: 20th Jan 2008, 12:52
